Solar App embed=1 problem since version 10.1x
Since version 10.1 I have a display problem with the parameter embed=1 with the SolarApp (see screenshot). This occurs with all common browsers. What could be the reason? Regards Oliver
Hi Oliver
Is this a emonSD or a self-build?
Can you post the “server info” from the admin page so we have more info?
Have you tried clearing the browser cache (often CTRL-F5 will do)?
Just to confirm the issue you see is only when using the “&embed=1” parameter, if you remove that from the url, the exact same url works perfectly ok, until you add the “&embed=1” back again, correct?
[edit] Actually, just tried this myself and confirmed the issue is there on one of my test servers too.
I’ve opened an issue on github, hopefully @TrystanLea or @emrys will pick it up.
Hi Paul,
thank you for your feedback.
I have emonSD upgraded from 9.9 to 10.1.2
That’s right, without embed=1 it works.
Server Information
Services
emonhub : Active Running
emoncms_mqtt : Active Running
feedwriter : Active Running - sleep 60s 165 feed points pending write
service-runner : Active Running
emonPiLCD : Active Exited
redis-server : Active Running
mosquitto : Active Running
Emoncms
Version : low-write 10.1.2
Modules : Administration | App v2.0.1 | Backup v1.1.4 | EmonHub Config v2.0.2 | Dashboard v2.0.3 | Device v2.0.0 | EventProcesses | Feed | Graph v2.0.1 | Input | Postprocess v2.1.0 | CoreProcess | Schedule | Network Setup v1.0.0 | sync | Time | User | Visualisation | WiFi v2.0.0
Git :
URL : GitHub - emoncms/emoncms: Web-app for processing, logging and visualising energy, temperature and other environmental data
Branch : * stable
Describe : 10.1.1-16-ga0c672e4
Server
OS : Linux 4.19.42-v7+
Host : tinyrx | tinyrx | (192.168.10.16)
Date : 2019-08-07 16:39:02 CEST
Uptime : 16:39:02 up 58 days, 4:52, 0 users, load average: 1.63, 1.45, 1.31
Memory
RAM : Used: 48.45%
Total : 975.62 MB
Used : 472.71 MB
Free : 502.91 MB
Disk
/ : Used: 89.83%
Total : 3.33 GB
Used : 2.99 GB
Free : 181.83 MB
/tmp : Used: 8.39%
Total : 28.33 GB
Used : 2.38 GB
Free : 24.49 GB
/boot : Used: 38.84%
Total : 59.95 MB
Used : 23.28 MB
Free : 36.66 MB
/_backup : Used: 7.41%
Total : 28.33 GB
Used : 2.1 GB
Free : 24.77 GB
/home/pi/data : Used: 10.06%
Total : 25.37 GB
Used : 2.55 GB
Free : 21.51 GB
/backup : Used: 58.59%
Total : 3.48 TB
Used : 2.04 TB
Free : 1.44 TB
HTTP
Server : Apache/2.4.25 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
Version : 5.5.5-10.1.38-MariaDB-0+deb9u1
Host : localhost:6379 (127.0.0.1)
Date : 2019-08-07 16:39:02 (UTC 02:00‌​)
Stats : Uptime: 5030392 Threads: 3 Questions: 146746142 Slow queries: 0 Opens: 46 Flush tables: 1 Open tables: 40 Queries per second avg: 29.171
Redis
Version : 3.2.6
Size : 910 keys (906.94K)
Uptime : 58 days
MQTT Server
Version : Mosquitto 1.4.10
Host : localhost:1883 (127.0.0.1)
PHP
Version : 7.0.33-0+deb9u3 (Zend Version 3.0.0)
Modules : apache2handler | calendar v7.0.33-0+deb9u3 | Core v7.0.33-0+deb9u3 | ctype v7.0.33-0+deb9u3 | curl v7.0.33-0+deb9u3 | date v7.0.33-0+deb9u3 | dom v20031129 | exif v7.0.33-0+deb9u3 | fileinfo v1.0.5 | filter v7.0.33-0+deb9u3 | ftp v7.0.33-0+deb9u3 | gd v7.0.33-0+deb9u3 | gettext v7.0.33-0+deb9u3 | hash v1.0 | iconv v7.0.33-0+deb9u3 | igbinary v2.0.1 | json v1.4.0 | libxml v7.0.33-0+deb9u3 | mcrypt v7.0.33-0+deb9u3 | mosquitto v0.4.0 | mysqli v7.0.33-0+deb9u3 | mysqlnd vmysqlnd 5.0.12-dev - 20150407 - Id: b5c5906d452ec590732a93b051f3827e02749b83 | openssl v7.0.33-0+deb9u3 | pcre v7.0.33-0+deb9u3 | PDO v7.0.33-0+deb9u3 | pdo_mysql v7.0.33-0+deb9u3 | Phar v2.0.2 | posix v7.0.33-0+deb9u3 | readline v7.0.33-0+deb9u3 | redis v3.1.1 | Reflection v7.0.33-0+deb9u3 | session v7.0.33-0+deb9u3 | shmop v7.0.33-0+deb9u3 | SimpleXML v7.0.33-0+deb9u3 | sockets v7.0.33-0+deb9u3 | SPL v7.0.33-0+deb9u3 | standard v7.0.33-0+deb9u3 | sysvmsg v7.0.33-0+deb9u3 | sysvsem v7.0.33-0+deb9u3 | sysvshm v7.0.33-0+deb9u3 | tokenizer v7.0.33-0+deb9u3 | wddx v7.0.33-0+deb9u3 | xml v7.0.33-0+deb9u3 | xmlreader v7.0.33-0+deb9u3 | xmlwriter v7.0.33-0+deb9u3 | xsl v7.0.33-0+deb9u3 | Zend OPcache v7.0.33-0+deb9u3 | zlib v7.0.33-0+deb9u3
Pi
Model : Raspberry Pi 3 Model B+ Rev 1.3 - 1 GB (Sony UK)
SoC : Broadcom BCM2835
Serial num. : D618EC32
Temperature : 74.14°C - 74.1°C
emonpiRelease : emonSD-13Jun18
File-system : read-only
Client Information
HTTP
Browser : Mozilla/5.0 (Macintosh; Intel Mac OS X 10.14; rv:68.0) Gecko/20100101 Firefox/68.0
Language : de,en-US;q=0.7,en;q=0.3
Window
Size : 1640 x 801
Screen
Resolution : 1680 x 1050
Thanks @misiu11 @pb66 I can confirm the same issue and note the github issue.
I’ve put this down to a cached css file… I cannot re-produce this error on my laptop as the old file has not been cached for me. Please let me know if more work is required.
