My controller dont reset to 100% SOC, he hang always at 105%.
I dont know, what is wrong.
The current shunt is set to 55.2V fully charged voltage and the shunt voltage is 54.8V. So should reset…
Can someone help?
Hello I have the same problem, did you find anything or get any update on this ? Mine is also 105%
Have the same Problem. Or lets say somtimes the SOC is correct.
If I would kknow how the SOC is calculated I maybe would find the error
Reason for wrong SOC was that I connected the Current Shunt the wrong way.
Bat side I connected to inverter and inverter to Bat side.
Found it when I had a look in the Ah In and Out. Was charging but the counter for Ah out was rising and not Ah In
