SMAsolar not logging to EmonCMS since upgrade (TypeError: ‘<’ not supported between instances of ‘int’ and ‘str)
Ok I have had my EmonPi running for many years, but latley finally made the jump to get onto current release which required repalcing the SD card and a restore.
So I am now running on:
low-write 10.2.7
But since the new SD card and backup restore SMAsolar is not logging to EmonCMS, I still see the input but there is no update to the inputs and they are N/A.
I have reviewed issues at the github page and I can’t see my problem:
https://github.com/openenergymonitor/emonhub/tree/master/conf/interfacer_examples/smasolar
I was receiving the error:
2021-02-04 10:00:38,860 ERROR SMASolar Failed to grab all the bytes needed for a Level 2 packet
2021-02-04 10:00:38,862 ERROR SMASolar [‘Traceback (most recent call last):\n’, ’ File “/opt/openenergymonitor/emonhub/src/interfacers/EmonHubSMASolarInterfacer.py”, line 268, in read\n inverter[“serialNumber”])\n’, ’ File “/opt/openenergymonitor/emonhub/src/smalibrary/SMASolar_library.py”, line 284, in request_data\n bluetoothbuffer = read_SMA_BT_Packet(btSocket, packet_send_counter, True, mylocalBTAddress)\n’, ’ File “/opt/openenergymonitor/emonhub/src/smalibrary/SMASolar_library.py”, line 73, in read_SMA_BT_Packet\n raise Exception(“Failed to grab all the bytes needed for a Level 2 packet”)\n’, ‘Exception: Failed to grab all the bytes needed for a Level 2 packet\n’]
So I downloaded the diagnostic tool and ran a test:
sudo service emonhub stop
hcitool scan
python SMASolarInverterPacketDebug.py aa:bb:cc:dd:ee:ff 0000 > test.txt
I found two issues that I identified missing packages:
sudo apt install python-bluetooth
sudo apt install python-requests
This then ran absolutely fine, so I restarted EmonHub with my fingers crossed… but no updates still.
I am now getting in the log:
2021-02-04 10:49:49,734 ERROR SMASolar ‘<’ not supported between instances of ‘int’ and ‘str’
2021-02-04 10:49:49,736 ERROR SMASolar [‘Traceback (most recent call last):\n’, ’ File “/opt/openenergymonitor/emonhub/src/interfacers/EmonHubSMASolarInterfacer.py”, line 283, in read\n for key in sorted(output):\n’, “TypeError: ‘<’ not supported between instances of ‘int’ and ‘str’\n”]
So I am now a bit lost, as all worked before and I would seem to have the latest code and suspect I might have hit some compatibility with the existing code and a newer library?
I also don’t see others with the issue, so it could be my config or other missing packages?
Tagging @stuart who I think wrote the code in case he can help - any suggestins welcome
Actually we should possibly tag @bwduncan too, it was him that added the sorted() aspect to the returned data.
The error message is correct you cannot compare str and ints, I don’t know what is expected or possible in this data, a numerical name perhaps? It can be a None that causes an issue when sorting dicts and lists in python, maybe not all the data is being retrieved as expected?
For Python3 the fix is apparently to use a “lambda”, see python 3.x - Sorting list containing value:None, results to TypeError: '<' not supported between instances of 'NoneType' and 'str' - Stack Overflow
Depending on the data’s key types the lambda could incorporate a type cast if needed I expect.
Thanks, I looked at line 283 again as clearly I looked at the wrong line last time and see:
    #self._log.debug("Building cargo")
    c = Cargo.new_cargo()
    c.rawdata = None
    #Sort the output to keep the keys in a consistent order
    c.names = []
    c.realdata = []
        c.names.append(output[key].Label)
        c.realdata.append(output[key].Value)
    #TODO: We need to revisit this once we know how multiple inverters communicate with us
    c.nodeid = inverter["NodeId"]
    c.nodename = inverter["inverterName"]
    #TODO: We should be able to populate the rssi number from the bluetooth signal strength
    c.rssi = 0
    #Inverter appears to kill our connection every 10 minutes, so disconnect after 8 minutes
    #to avoid errors in log files
    if self._is_it_time_to_disconnect():
        self._log.info("Disconnecting Bluetooth after timer expired")
        SMASolar_library.logoff(self._btSocket, self._packet_send_counter, self.mylocalBTAddress, self.MySerialNumber)
        self._reset_time_to_disconnect_timer()
        self._btSocket.close()
        self._btSocket = None
    self._log.debug("Returning cargo")
    return c
Looks like Dec 9th 2019 is when this code was added?
https://github.com/openenergymonitor/emonhub/commits/master/src/interfacers/EmonHubSMASolarInterfacer.py
Wonder if I can roll back to the version before the sort code was added (which I am not sure what it adds?)
I’m sure I’ve already fixed that, this was part of the Python 3 upgrade.
22nd June 2020 was the last change I saw - “bwduncan Fixups for SMA.
b8246cb”
Thanks for tagging me in. I hope I can help!
I didn’t add sorted(), that was already there, I just moved the code around:
I think we need to see the dict. It looks like there is an unrecognised readingtype getting passed through
We should handle that more gracefully. We could hack all the ints to strs but I think it’s better to add them to spotvalues. I’m not sure if there is any value in adding this “raw format for debugging”, so we could just delete that branch.
Please can you add
self._log.error('%s', output)
on line 282 of /opt/openenergymonitor/emonhub/src/interfacers/EmonHubSMASolarInterfacer.py and restart emonhub?
Bruce
I’ve just took another look at the repo the code is currently as quoted above and the last update to master branch was 9days ago.
My bad, the “blame” function in github didn’t link back. I see now Stuart put it in back in 2017.
I agree, perhaps for more specialist interfacers some example data frames and/or communications are needed in the comments. Perhaps even a commented out log message so that users can uncomment for really in depth debugging, dev debugging. Obviously we don’t want the full content of every communication printed to the log under normal running, but the absence of such info often restricts debugging to those that have the devices.
Ok thanks, I think then I have an old version, as I see in that commit:
import time
import sys
import subprocess, shlex, shutil
import traceback
import re
import Cargo
but the file on my EmonPi has no Shlex, Shutil after subprocess so perhaps is an older revision.
I just ran an emonhub update from the GUI but it did not seem to pull down an updated EmonHubSMASolarInterfacer.py and I still have the same file, without the changes I can see in the commit fromw what I can see. Will dig further…
Thanks, just seen this, will try… (still not convinced I have the latest EmonHubSMASolarInterfacer.py will maybe checksum against latest git copy)
No worries!
I fully agree! We could have debug logs in the code all the time which are only enabled when users set debug logging in the config file. Sprinkle the code liberally with self._log.debug() and it will remain silent unless needed.
Bruce
Totally agree, in principle, however, the 5 log levels in emonhub have not been used wisely over the years and “debug” is needed for user level debugging, “are my nodes being received?”, “is the url to xyz correct?” etc, I think dev level debugging would make the current debug level too busy, perhaps the levels need addressing throughout? Or maybe another level is needed for everything to be logged? I thought as the examples were in the comments in the code, where any changes would need to be applied, commented-out “extreme verbose” messages could be simply uncommented.
The other issue is with a system wide “extreme verbose” there would be so much more info from other interfacers it might have a negative impact. Different log levels per interfacer is something I have pondered before, but it never got any further than a “possibilities” list.
That’s a good point. Here is how often the logging functions are used:
  2 exception
 45 error
 57 warning
106 info
139 debug
So we could have critical for a new purpose, it is the highest level so will always log. There is quite a lot of logging which just isn’t that useful for debugging, so a clean up would be well worth it. There are also a bunch of logging calls inside exception handlers which aren’t calling log.exception so the exception is lost. Would be nice to tidy that up, too.
Log levels could be set per-interfacer. We would need each one to do self._log = logging.getLogger(__name__). This would give more specific messages, since at the moment everything just uses the same logger called “EmonHub”. If we did that, it would be possible to set debugging logs for only one interfacer, for example.
I am fairly strongly against having code as commented-out blobs. It doesn’t get maintained when things change, it’s fragile and pretty unfriendly for users. If we really want to have code which isn’t run, wrap it in if DEBUG:, but I suspect we would be re-inventing the logging module if we did that.
Hmm, my attempts to insert this are not working, emoncms fails to start and does not like the syntax:
g-file=/etc/emonhub/emonhub.conf
  File "/usr/local/bin/emonhub/emonhub.py", line 26, in <module>
    from interfacers import *
  File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubSMASolarInterfacer.py", line 282
TabError: inconsistent use of tabs and spaces in indentation
You have used tabs instead of spaces. Your editor may be “helping” you…
ok - my vi-fu needs some practice it seems…
Hello vi! :wave:
:set noexpandtabs
Ok - schoolboy error corrected…
L2 Payload=
    00000000: 01 77 23 40 38 00 1c 60 0f 08 00 00 19 08 00 00
    00000010: 15 08 00 00 15 08 00 00 01 00 00 00
L2 Checksu= c1 66
L2    END = 7e
2021-02-04 14:12:41,172 ERROR    SMASolar   {'TotalYield': SpotValueOutput(Label='TotalYield', Value=27525509.0), 'DayYield': SpotValueOutput(Label='DayYield', Value=2758.0), 'Ph1Power': SpotValueOutput(Label='Ph1Power', Value=314.0), 'Ph2Power': SpotValueOutput(Label='Ph2Power', Value=0.0), 'Ph3Power': SpotValueOutput(Label='Ph3Power', Value=0.0), 'ACTotalPower': SpotValueOutput(Label='ACTotalPower', Value=314.0), 'DCVoltage1': SpotValueOutput(Label='DCVoltage1', Value=317.62), 'DCVoltage2': SpotValueOutput(Label='DCVoltage2', Value=320.02), 'DCCurrent1': SpotValueOutput(Label='DCCurrent1', Value=0.513), 'DCCurrent2': SpotValueOutput(Label='DCCurrent2', Value=0.508), 'Ph1ACVolt': SpotValueOutput(Label='Ph1ACVolt', Value=239.67), 'Ph2ACVolt': SpotValueOutput(Label='Ph2ACVolt', Value=0.0), 'Ph3ACVolt': SpotValueOutput(Label='Ph3ACVolt', Value=0.0), 18003: SpotValueOutput(Label='DebugX4653', Value=1311), 18004: SpotValueOutput(Label='DebugX4654', Value=0), 18005: SpotValueOutput(Label='DebugX4655', Value=0), 'ACGridFreq': SpotValueOutput(Label='ACGridFreq', Value=50.01), 'OperatingTime': SpotValueOutput(Label='OperatingTime', Value=22021.8689), 'FeedInTime': SpotValueOutput(Label='FeedInTime', Value=21343.4419), 'InvTemperature': SpotValueOutput(Label='InvTemperature', Value=20.63)}
2021-02-04 14:12:41,174 ERROR    SMASolar   '<' not supported between instances of 'int' and 'str'
2021-02-04 14:12:41,177 ERROR    SMASolar   ['Traceback (most recent call last):\n', '  File "/opt/openenergymonitor/emonhub/src/interfacers/EmonHubSMASolarInterfacer.py", line 282, in read\n    for key in sorted(output):\n', "TypeError: '<' not supported between instances of 'int' and 'str'\n"]
Every day a schoolday!
Looking good!
In [47]: pprint.pprint({k:v for k,v in c.items() if isinstance(k, int)})
{18003: SpotValueOutput(Label='DebugX4653', Value=1311),
 18005: SpotValueOutput(Label='DebugX4655', Value=0)}
Do those look like things we are interested in logging? My vote is just to ignore those things we don’t understand. Maybe a debug log message if @pb66 and I get a grand new logging masterplan!
For now, please can you go to line 378 of /opt/openenergymonitor/emonhub/src/smalibrary/SMASolar_library.py and comment out that line? It should be
                 outputlist[readingtype] = SpotValueOutput("DebugX{0:04x}".format(readingtype), value)
and removing/commenting it should get you going again.
Bruce
Thanks Bruce, that did the trick, feed is now updating again as expected. Not sure when the debug came in, I do not recall seeing those feeds under that input before I did the SD card replacement.
Just need to go remove the extra debug now (packettrace = 0 in emonhub.conf)
That’s great! That local change will probably block future updates so I will prepare a pull request to fix this in a more sustainable way.
Bruce
