I have a Landis+Gyr G470 672 gas mater is my smart gas mater connected to my electricity meter as most likely is connected can someone confirm if the gas mater is connected to home area network (HAN)
Hi Zakir, is your gas meter submitting half hourly readings to your energy supplier? Can you check online or via an app. If the answer is yes readings are being submitted then your gas meter is connected.
Welcome,
Doe you have an IHD (In House Device) that shows the gas and electric? The IHD also connects to the HAN (Home Area Network) so it should show therefore what is connected. If the IHD only shows one or the other, then both meters are not connected to the HAN.
