Has anyone used a Diehl Sharky 774 heat meter with the ESP8266 WIFI Heatpump Monitor instead of using the Kamstrup 402/403.
They same like exactly the same thing.
Heres the specs on it:
http://www.diehl.com/fileadmin/diehl-metering/pdb/DE_EN_Web/familie85921045372/SHARKY_774_compact.pdf
Will the ATmega328 core on the ESP8266 Heatpump board translate the MODBUS to emoncms via emonhub?, or are there parameters set up specifically for Kamstrup 402/403?
