Hello, so I have added a recently purchases emonTx via serial connection to a pi with emoncms running on it. I have the 4 current feeds, voltage feed, and superfluous other feeds (message, energy, temp, pulse).
I tried following and adjusting the instructions at Solar PV Guide - but apparently not correctly
I believe I have a ‘Type 2’ system, 2 120V legs coming in from the grid (Black and Red), then the two wires from the solar system come in and attach to the grid feed, and then that connects to the main switch. I was trying to combine the two grid inputs to get the import feeds, then to log the two solar to get the solar and then all 4 to get use.
I’m confident that I have the CT’s setup correctly. As I’m writing this, both grids are negative, in the screen shot though, one is at 122W and the other is 2W, with the solar being 277 and 273. So, I would assume import of 124, solar 550 and use of 674? But what I’ve got currently is obviously very wrong
Here’s what I have on the inputs screen:
And the definition for the two inputs:
On the feeds page:
And lastly my app:
