is it possible set the temperature value with mqtt message.
I can take advantage of all the functions of the wifi relay with a remote temperature sensor.
Sorry, I’m afraid this is not possible
If you want to use a remote temperature sensor you will need to control the relay remotely e.g. via NodeRED works well.
Yes,
nodered is fantastic and I would like to use to send the temperature value.
If I can send the value via serial, maybe can create a mqtt topic to set the temperature.
