Hello.
I have an emonBase that was flashed with image emonSD-30Oct18 and everything was running fine until I did a full update last Sunday. Afterwards, I noticed 2 issues:
- the update didn’t updated any OS packages as I ran apt update and there where 141 packages not updated
- in the Admin page I see that service-runner is stuck on Activating Auto-restart. I checked the status of the service and it’s not started and shows a failure. A restart of the service doesn’t do anything.
pi@emonpi:~ $ sudo systemctl status service-runner
● service-runner.service - Emoncms service-runner Input Script
Loaded: loaded (/var/www/emoncms/scripts/services/service-runner/service-runner.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2020-08-25 21:59:47 WEST; 6s ago
Docs: https://github.com/emoncms/emoncms/blob/master/scripts/services/install-service-runner-update.md
Process: 3353 ExecStart=/usr/bin/python3 /var/www/emoncms/scripts/services/service-runner/service-runner.py (code=exited, status=1/FAILURE)
Main PID: 3353 (code=exited, status=1/FAILURE)
Aug 25 21:59:47 emonpi systemd[1]: service-runner.service: Failed with result 'exit-code'.
Running the update again just shows “service-runner trigger sent” in the log window and then nothing happens.
Can anyone please let me know how can I fix this? Thanks!
Full update log.
pi@emonpi:~ $ cat /var/log/emoncms/emonpiupdate.log
Starting update via service-runner-update.sh (v2.0) >
- emonSD version: emonSD-30Oct18
emonSD base image check passed...continue update
git pull /home/pi/emonpi
enable-ssh
enable-ssh-button
gpiozero-enable-ssh
greeebs-patch-1
* master
python-systemd-servicerunner
On branch master
Your branch is up-to-date with 'origin/master'.
nothing to commit, working tree clean
From https://github.com/openenergymonitor/emonpi
73a63d2..16e4876 master -> origin/master
* [new branch] python3_lcd -> origin/python3_lcd
Updating 73a63d2..16e4876
Fast-forward
.gitignore | 1 +
firmware/compile.sh | 12 -
firmware/compiled/archive/README.md | 3 +
firmware/compiled/latest.hex | 2264 ++++++++++++++++++-----------------
firmware/compiled/readme.md | 5 +-
firmware/compiled/update | 2 +-
firmware/platformio.ini | 2 +-
firmware/platformio.md | 4 +
firmware/readme.md | 19 +-
lcd/README.md | 37 +-
lcd/disablessh.sh | 2 -
lcd/emonPiLCD.cfg | 4 +
lcd/emonPiLCD.py | 447 +++----
lcd/emonPiLCD.service | 40 +-
lcd/emonPiLCD_detect.py | 14 +
lcd/emonPiLCD_detect.sh | 11 +-
lcd/emonPiLCD_update.py | 41 +-
lcd/emonPiLCD_write.py | 29 +
lcd/enablessh.sh | 2 -
lcd/gsmhuaweistatus.py | 20 +-
lcd/i2c_lib.py | 35 -
lcd/install.sh | 45 +
lcd/lcd_test.py | 14 +-
lcd/lcddriver.py | 37 +-
lcd/testing/emonPiLCD.py | 191 ++-
lcd/testing/lcd_test_IPclock.py | 113 +-
lcd/testing/push_and_hold.py | 12 +-
lcd/testing/test.py | 63 +-
md5sum.py | 28 +-
factoryreset => old-factoryreset.sh | 0
wifiAP/networklog.sh | 2 +-
31 files changed, 1744 insertions(+), 1755 deletions(-)
delete mode 100755 firmware/compile.sh
create mode 100644 firmware/compiled/archive/README.md
create mode 100755 lcd/emonPiLCD_detect.py
create mode 100755 lcd/emonPiLCD_write.py
delete mode 100755 lcd/i2c_lib.py
create mode 100755 lcd/install.sh
rename factoryreset => old-factoryreset.sh (100%)
Main Update Script
Date: Sun 23 Aug 20:42:22 WEST 2020
EUID: 1000
usrdir: /home/pi
type: all
firmware: none
Checking environment:
- pi user found
EUID: 1000
Hardware detected: rfm2pi
Stopping emonPiLCD service
Display update message on LCD
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Reading package lists...
Building dependency tree...
Reading state information...
rng-tools is already the newest version (2-unofficial-mt.14-1).
python-gpiozero is already the newest version (1.5.0).
python-rpi.gpio is already the newest version (0.6.5~stretch-1).
The following packages were automatically installed and are no longer required:
libarchive13 liblzo2-2
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 141 not upgraded.
Requirement already up-to-date: paho-mqtt in /usr/local/lib/python2.7/dist-packages
git pull /home/pi/RFM2Pi
* master
On branch master
From https://github.com/openenergymonitor/RFM2Pi
e5d874d..1658310 master -> origin/master
Updating e5d874d..1658310
Fast-forward
hardware/readme.md | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
git pull /home/pi/usefulscripts
* master
On branch master
Already up-to-date.
git pull /home/pi/huawei-hilink-status
* master
On branch master
Already up-to-date.
git pull /home/pi/oem_node-red
* master
On branch master
Already up-to-date.
Start emonhub update script:
emonHub update started
- usr directory: /home/pi
git pull /home/pi/emonhub
* emon-pi
On branch emon-pi
Your branch is up-to-date with 'origin/emon-pi'.
Untracked files:
(use "git add <file>..." to include in what will be committed)
src/src
nothing added to commit but untracked files present (use "git add" to track)
From https://github.com/openenergymonitor/emonhub
bbd2e71..e443b94 emon-pi -> origin/emon-pi
* [new branch] MQTTSubscriberInterfacer -> origin/MQTTSubscriberInterfacer
* [new branch] SDS011 -> origin/SDS011
* [new branch] Tx3e_calibration -> origin/Tx3e_calibration
5d239b3..a97f849 env_example -> origin/env_example
* [new branch] include_serial_number -> origin/include_serial_number
cb798e7..0a82be4 lanip-status -> origin/lanip-status
* [new branch] master -> origin/master
5e0fa7d..1a49197 redis_config_interface -> origin/redis_config_interface
* [new branch] stable -> origin/stable
f3f78d8..1ce386a unitless_decoder -> origin/unitless_decoder
* [new tag] 2.1.6 -> 2.1.6
* [new tag] 2.1.3 -> 2.1.3
* [new tag] 2.1.4 -> 2.1.4
* [new tag] 2.1.5 -> 2.1.5
Updating bbd2e71..e443b94
Fast-forward
conf/emonpi.default.emonhub.conf | 2 +-
.../directserial-serialtx3e/readme.md | 2 +
configuration.md | 57 ++++++----
src/interfacers/EmonHubTeslaPowerWallInterfacer.py | 118 +++++++++++++++++++++
src/interfacers/__init__.py | 1 +
5 files changed, 156 insertions(+), 24 deletions(-)
create mode 100644 src/interfacers/EmonHubTeslaPowerWallInterfacer.py
Creating emonhub logfile
Symlinking emonhub.conf to /etc/emonhub/emonhub.conf
emonhub.service already installed
Running emonhub automatic node addition script
[[5]]
Node 5 already present
[[6]]
Node 6 already present
[[7]]
Node 7 already present
[[8]]
Node 8 already present
[[9]]
Node 9 already present
[[10]]
Node 10 already present
[[11]]
Node 11 already present
[[12]]
Node 12 already present
[[13]]
Node 13 already present
[[14]]
Node 14 already present
[[15]]
Node 15 already present
[[16]]
Node 16 already present
[[19]]
Node 19 already present
[[20]]
Node 20 already present
[[21]]
Node 21 already present
[[22]]
Node 22 already present
[[23]]
Node 23 already present
[[24]]
Node 24 already present
[[25]]
Node 25 already present
[[26]]
Node 26 already present
Start emoncms update:
Emoncms update started
Emoncms update script V1.3 (26th March 2019)
- emoncms directory: /var/www/emoncms
current settings.php md5: 59e80f731935867f5f93753d49c0fe86
Default settings.php md5: 59e80f731935867f5f93753d49c0fe86
settings.php has NOT been user modifed
Checking status of /var/www/emoncms git repository
Fetching origin
From https://github.com/emoncms/emoncms
- [deleted] (none) -> origin/csv_export_phpfina_fix_dmy
0767740f..bc0e6c25 stable -> origin/stable
* [new branch] auto_detect_timezone -> origin/auto_detect_timezone
* [new branch] emoncms_component_table -> origin/emoncms_component_table
* [new branch] kwh_hh -> origin/kwh_hh
0de83f1d..bc0e6c25 master -> origin/master
* [new branch] timezone_support_csv_export -> origin/timezone_support_csv_export
* [new tag] 10.2.5 -> 10.2.5
* [new tag] 10.2.3 -> 10.2.3
* [new tag] 10.2.4 -> 10.2.4
- git branch: stable
- no local changes
- running: git pull origin stable
Branch stable set up to track remote branch stable from origin.
Updating 0767740f..bc0e6c25
Fast-forward
.travis.yml | 5 +
Lib/EmonLogger.php | 59 +-
Lib/dbschemasetup.php | 55 +-
Lib/email.php | 89 +-
Lib/enum.php | 29 +-
Lib/process_old_settings.php | 22 +-
Lib/units.php | 6 +-
Modules/admin/admin_controller.php | 27 +-
Modules/admin/admin_main_view.php | 26 +-
Modules/admin/admin_model.php | 69 +-
Modules/feed/Views/feedlist_view.php | 2 -
Modules/feed/engine/MysqlMemory.php | 11 +-
Modules/feed/engine/MysqlTimeSeries.php | 936 ++++++++++++---------
Modules/feed/engine/TemplateEngine.php | 67 +-
Modules/feed/feed_model.php | 41 +-
Modules/input/input_methods.php | 1 +
Modules/process/Views/process_ui.js | 30 +-
Modules/process/Views/process_ui.php | 14 +-
Modules/process/process_processlist.php | 76 +-
Modules/user/login_block.php | 9 +-
Modules/user/user.js | 4 +-
Modules/user/user_controller.php | 2 +-
Modules/user/user_menu.php | 5 +-
Modules/user/user_model.php | 20 +-
Theme/emoncms-logo.svg | 381 +++++++++
composer.json | 12 +-
core.php | 180 ++--
default-settings.php | 6 +-
docs/RaspberryPi/language_support.md | 49 ++
example.settings.php | 6 +-
index.php | 702 ++++++++--------
locale.php | 25 +-
param.php | 71 +-
php-info.php | 2 +-
process_settings.php | 20 +-
readme.md | 40 +-
route.php | 8 +-
scripts/examples/mqtt_input_publisher.php | 25 +-
scripts/services/emoncms_mqtt/emoncms_mqtt.php | 11 +-
scripts/services/install-service-runner-update.md | 6 +-
scripts/services/service-runner/service-runner.py | 115 +--
.../services/service-runner/service-runner.service | 4 +-
version.txt | 2 +-
43 files changed, 2108 insertions(+), 1162 deletions(-)
create mode 100755 Theme/emoncms-logo.svg
create mode 100644 docs/RaspberryPi/language_support.md
NEW default settings.php md5: 59e80f731935867f5f93753d49c0fe86
settings.php not updated
Updating Emoncms Modules
Updating /var/www/emoncms/Modules/app module
Fetching origin
From https://github.com/emoncms/app
- [deleted] (none) -> origin/octopus_outgoing
90a3dc4..e5d51a4 stable -> origin/stable
6727a6e..e5d51a4 master -> origin/master
- git tags: 2.1.1
- no local changes
Updating 90a3dc4..e5d51a4
Fast-forward
Readme.md | 29 +-
Views/css/app.css | 6 +-
app_controller.php | 19 +-
app_model.php | 2 +-
apps/OpenEnergyMonitor/graph-nav.php | 3 +-
apps/OpenEnergyMonitor/myelectric2/myelectric2.php | 2 +
apps/OpenEnergyMonitor/myenergy/myenergy.php | 1 +
apps/OpenEnergyMonitor/mysolarpv/mysolarpv.php | 2 +
apps/OpenEnergyMonitor/mysolarpvbattery/app.json | 5 +
.../mysolarpvbattery/mysolarpvbattery.php | 1210 ++++++++++++++++++++
.../mysolarpvdivert/mysolarpvdivert.php | 39 +-
apps/OpenEnergyMonitor/octopus/octopus.php | 311 +++--
apps/template/app.json | 6 +-
apps/template/template.php | 20 +-
composer.json | 5 +-
module.json | 2 +-
16 files changed, 1515 insertions(+), 147 deletions(-)
create mode 100644 apps/OpenEnergyMonitor/mysolarpvbattery/app.json
create mode 100644 apps/OpenEnergyMonitor/mysolarpvbattery/mysolarpvbattery.php
Updating /var/www/emoncms/Modules/config module
Fetching origin
From https://github.com/emoncms/config
8d278bc..d28ff1e stable -> origin/stable
- git tags: 2.0.5
- no local changes
Updating 8d278bc..d28ff1e
Fast-forward
.travis.yml | 14 ++
LICENSE.txt | 619 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
composer.json | 17 ++
3 files changed, 650 insertions(+)
create mode 100644 .travis.yml
create mode 100644 LICENSE.txt
create mode 100644 composer.json
Updating /var/www/emoncms/Modules/dashboard module
Fetching origin
From https://github.com/emoncms/dashboard
3b92632..3f3404f stable -> origin/stable
7c73b21..81772de master -> origin/master
* [new tag] 2.0.8 -> 2.0.8
- git tags: 2.0.7
- no local changes
Updating 3b92632..3f3404f
Fast-forward
Views/js/render.js | 19 +++++-
composer.json | 2 +-
dashboard_controller.php | 2 +-
module.json | 2 +-
widget/bar/bar_render.js | 10 ---
widget/battery/battery_render.js | 13 +---
widget/button/button_render.js | 9 +--
widget/cylinder/cylinder_render.js | 20 +++---
widget/dewpoint/dewpoint_render.js | 9 ---
widget/dial/dial_render.js | 98 +++++++++++++--------------
widget/feedtime/feedtime_render.js | 9 ---
widget/feedvalue/feedvalue_render.js | 67 ++++++++-----------
widget/frostpoint/frostpoint_render.js | 9 ---
widget/heatindex/heatindex_render.js | 9 ---
widget/humidex/humidex_render.js | 8 ---
widget/isactivefeed/isactivefeed_render.js | 8 ---
widget/jgauge/jgauge_render.js | 74 +++++++++++---------
widget/jgauge2/jgauge2_render.js | 104 ++++++++++++++++++-----------
widget/kwhperiod/kwhperiod_render.js | 15 -----
widget/led/led_render.js | 16 ++---
widget/signal/signal_render.js | 10 ---
widget/sun/sun_render.js | 8 ---
widget/thermometer/thermometer_render.js | 13 ----
widget/thresholds/thresholds_render.js | 8 ---
widget/windrose/windrose_render.js | 45 ++++++++-----
25 files changed, 251 insertions(+), 336 deletions(-)
Updating /var/www/emoncms/Modules/device module
Fetching origin
From https://github.com/emoncms/device
34f09b1..97b763e stable -> origin/stable
bfc5de3..f08ba45 master -> origin/master
* [new tag] 2.0.6 -> 2.0.6
- git tags: 2.0.5
- no local changes
Updating 34f09b1..97b763e
Fast-forward
device_controller.php | 8 +
device_model.php | 62 +++++
module.json | 2 +-
5 files changed, 693 insertions(+), 3 deletions(-)
Updating /var/www/emoncms/Modules/graph module
Fetching origin
From https://github.com/emoncms/graph
5124499..6c18b0c stable -> origin/stable
2635583..b6e4ce1 master -> origin/master
- git tags: 2.0.9
- no local changes
Updating 5124499..6c18b0c
Fast-forward
graph.css | 4 ++++
graph.js | 17 +++++++++++++++--
view.php | 1 +
vis.helper.js | 4 ++--
4 files changed, 22 insertions(+), 4 deletions(-)
Updating /var/www/emoncms/Modules/wifi module
Fetching origin
From https://github.com/emoncms/wifi
274bcd5..0fd4a54 stable -> origin/stable
2b69da7..b9b0dbf master -> origin/master
* [new tag] 2.0.3 -> 2.0.3
- git tags: 2.0.0-29-g274bcd5
- no local changes
Updating 274bcd5..0fd4a54
Fast-forward
module.json | 2 +-
view.html | 59 +++--
wifi.php | 7 +-
wifi_controller.php | 2 +-
6 files changed, 670 insertions(+), 24 deletions(-)
Updating postprocess module
Fetching origin
From https://github.com/emoncms/postprocess
0e2d78f..5c50627 stable -> origin/stable
6363aeb..5c50627 master -> origin/master
- git tags: 2.1.0-21-g0e2d78f
- no local changes
Updating 0e2d78f..5c50627
Fast-forward
common.php | 184 +++++++++++++++++++--
postprocess-module/module.json | 2 +-
postprocess-module/postprocess_controller.php | 59 ++++++-
postprocess-module/view.js | 127 ++++++++-------
processes/average.php | 120 ++++++++++++++
processes/basic_formula.php | 224 ++++++++++++++++----------
processes/batterysimulator.php | 185 +++++++++++++++++++++
processes/constantflow_tokwh.php | 32 ++--
processes/liquidorairflow_tokwh.php | 26 +--
10 files changed, 770 insertions(+), 191 deletions(-)
create mode 100644 processes/average.php
create mode 100644 processes/batterysimulator.php
Updating sync module
Fetching origin
From https://github.com/emoncms/sync
afd953d..109816f stable -> origin/stable
- git tags: 2.0.5
- no local changes
Updating afd953d..109816f
Fast-forward
1 file changed, 1 insertion(+), 1 deletion(-)
Updating backup module
Fetching origin
From https://github.com/emoncms/backup
70894e1..da23f08 stable -> origin/stable
d65a722..439c981 master -> origin/master
* [new tag] 2.2.4 -> 2.2.4
- git tags: 2.2.2-6-g70894e1
- no local changes
Updating 70894e1..da23f08
Fast-forward
backup-module/module.json | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
Auto Installation of Emoncms Modules
- graph module already installed
- device module already installed
- postprocess module already installed
- sync module already installed
- backup module already installed
/home/pi/emonpi/sudoers.d/emoncms-rebootbutton: parsed OK
emoncms-rebootbutton sudoers entry installed
/home/pi/emonpi/sudoers.d/emoncms-filesystem: parsed OK
emoncms-filesystem sudoers entry installed
/home/pi/emonpi/sudoers.d/wifi-sudoers: parsed OK
wifi-sudoers sudoers entry installed
www-data : www-data video systemd-journal
SERVICES
emoncms_mqtt.service already installed
feedwriter.service already installed
service-runner.service already installed
Reloading systemctl deamon
Update Emoncms database
Restarting Services...
- sudo systemctl restart feedwriter.service
--- ActiveState=active ---
- sudo systemctl restart emoncms_mqtt.service
- sudo systemctl restart emonhub.service
Symlinking emonpiupdate.log
Installing emoncms logrotate...
Now setting up Logrotate...
Backing up old logrotate configuration...
Linked to new logrotate configuration...
Backing up old logrotate cron job...
mv: cannot stat '/etc/cron.daily/logrotate': No such file or directory
Linked to new logrotate cron job...
Completed
Completed
Running logrotate...
set log rotate config owner to root
Emoncms update script complete
Starting emonPi LCD service..
emonPi update done: Sun 23 Aug 20:43:29 WEST 2020
restarting service-runner
service-runner: no process found
