I try to send some text sensor value to emonCMS: 04B68692183180
Sadly this is not working. It cuts off after 04.
Any trick/workaround to push the full 04B68692183180 line to emonCMS?
Which method are you using to post data to OEM?
I suspect that OEM doesn’t accept hexadecimal numbers at all, but if it did you should prefix the number with 0x
so that it knows the number is hex. I.e. 0x04B68692183180
If that doesn’t work, you’ll need to convert the hex to decimal before sending it.
If the data enters via emonHub (r.f. or serial, not Wi-Fi/Ethernet), information for emonHub and the formats it accepts is here:
https://docs.openenergymonitor.org/emonhub/configuration.html
