Is it possible for emoncms to send a command to a IOT device, like a Raspberry Pi or Arduino?
Another IOT platform, “MediaTek Cloud Sandbox” has such a function, which works quite well on the Linkit One dev board, but it’s not nearly as nice to work with as emoncms.
Basically you add a add a “Control” option in their web portal, and then monitor for it to change via some Arduino code (I’m sure it could be done from a Raspberry Pi with Python as well) and then whenever that command is “triggered” in the web portal, the Arduino would perform the action.
Here’s a quite tutorial to switch on / off the onboard LED on an Arduino: https://docs.labs.mediatek.com/resource/linkit-smart-7688/en/tutorials/cloud-services/mediatek-cloud-sandbox/remote-control-of-an-on-board-led-with-mcs-and-arduino-bridge-library
NOW, can emoncms (I’m using emoncms.org, but could install it locally as well, if I have to?) to something like this? I didn’t see in the dashboard, so perhaps it’s something totally different from what I’d expect to look for?
