I’ve had my emonpi for years and my first emonTX for about 18 months.
I got this second (pre-configured id 16) emonTX (and AC adaptor) from the store about 2 months ago and it has been happily reading and sending back a number of temperatures from a breakout board.
But i’ve come to plug in two CT clamps today and I can’t get anything to show. (clamps also from store)
Occasional odd numbers like 1 and 9.
But when I put 3kW of load through them (kettle or immersion), nothing registers.
I see the voltage 236.3, 236.9 etc happily changing.
I see no difference in settings for both my TX in emonhub.conf
I haven’t touched these, this has always been in the emonpi
[[15]]
nodename = emontx3cm15
[[[rx]]]
names = MSG, Vrms, P1, P2, P3, P4, E1, E2, E3, E4, T1, T2, T3, pulse
datacodes = L,h,h,h,h,h,L,L,L,L,h,h,h,L
scales = 1,0.01,1,1,1,1,1,1,1,1,0.01,0.01,0.01,1
units = n,V,W,W,W,W,Wh,Wh,Wh,Wh,C,C,C,p
whitening = 1
[[16]]
nodename = emontx3cm16
[[[rx]]]
whitening = 1
And I see info in the emonhub logs being sent to the Pi.
2022-02-01 15:17:12,571 DEBUG RFM2Pi 5418 NEW FRAME : OK 16 18 85 85 85 116 8 92 85 84 85 85 85 85 85 84 85 85 85 85 85 85 85 85 85 85 85 85 85 85 85 227 86 222 83 101 32 87 85 85 85 (-72)
2022-02-01 15:17:12,578 DEBUG RFM2Pi 5418 Timestamp : 1643728632.57
2022-02-01 15:17:12,579 DEBUG RFM2Pi 5418 From Node : 16
2022-02-01 15:17:12,580 DEBUG RFM2Pi 5418 Values : [71, 238.41, 9, 1, 0, 0, 1, 0, 0, 0, 9.5, 16.75, 300, 2]
2022-02-01 15:17:12,581 DEBUG RFM2Pi 5418 RSSI : -72
2022-02-01 15:17:12,582 DEBUG RFM2Pi 5418 Sent to channel(start)' : ToEmonCMS
2022-02-01 15:17:12,583 DEBUG RFM2Pi 5418 Sent to channel(end)' : ToEmonCMS
2022-02-01 15:17:12,615 DEBUG MQTT Publishing: emon/emontx3cm16/MSG 71
2022-02-01 15:17:12,618 DEBUG MQTT Publishing: emon/emontx3cm16/Vrms 238.41
2022-02-01 15:17:12,620 DEBUG MQTT Publishing: emon/emontx3cm16/P1 9
2022-02-01 15:17:12,622 DEBUG MQTT Publishing: emon/emontx3cm16/P2 1
2022-02-01 15:17:12,624 DEBUG MQTT Publishing: emon/emontx3cm16/P3 0
2022-02-01 15:17:12,626 DEBUG MQTT Publishing: emon/emontx3cm16/P4 0
2022-02-01 15:17:12,628 DEBUG MQTT Publishing: emon/emontx3cm16/E1 1
2022-02-01 15:17:12,631 DEBUG MQTT Publishing: emon/emontx3cm16/E2 0
2022-02-01 15:17:12,633 DEBUG MQTT Publishing: emon/emontx3cm16/E3 0
2022-02-01 15:17:12,635 DEBUG MQTT Publishing: emon/emontx3cm16/E4 0
2022-02-01 15:17:12,637 DEBUG MQTT Publishing: emon/emontx3cm16/T1 9.5
2022-02-01 15:17:12,640 DEBUG MQTT Publishing: emon/emontx3cm16/T2 16.75
2022-02-01 15:17:12,642 DEBUG MQTT Publishing: emon/emontx3cm16/T3 300
2022-02-01 15:17:12,644 DEBUG MQTT Publishing: emon/emontx3cm16/pulse 2
2022-02-01 15:17:12,646 DEBUG MQTT Publishing: emon/emontx3cm16/rssi -72
2022-02-01 15:17:12,648 INFO MQTT Publishing: emonhub/rx/16/values 71,238.41,9,1,0,0,1,0,0,0,9.5,16.75,300,2,-72
I’ve checked the dip switches and it seems i’m set for UK
So i’m at a bit of a loss what to look at next.
Are there any other configs I need to look at on my emonpi?
Any help would be very much appreciated.
Cheers, Mick
