Seasonal switching between Octopus Cosy and Intelligent Go: a year of data and a battery planner
Follow-up to my year of living green write-up. I took a year of daily data from my house (10.8 kWp solar, Powerwall 3, Octopus Cosy 9 heat pump, Model Y) and costed every day on Cosy and Intelligent Go with a half-hourly battery planner (a small linear programme per day), using the rates in force on each day. Percentages only, no pounds.
Result: against my actual switching (23 Oct to Cosy, 5 Apr back to Go), Go all year would have cost 5% less and Cosy all year 16% more. The best dates in hindsight (22 Nov, 10 Feb) would have cost about 8% less.
Why the tariffs trade places: on a cold winter day Cosy’s three cheap windows let the battery refill three times and cover the 16:00–19:00 peak, while on Go it fills once overnight and is empty by late morning. Cosy’s cheap rate is more than double Go’s though, so its winter edge is modest, and as demand falls in February one cheap refill goes much further and Go wins.
The planner is 12 kWh usable, 5 kW, 95% efficient each way, grid charging only in the cheap windows, export 12p, with the within-day demand shape assumed (80% flat, 20% typical profile) because it works from daily totals. Replaying days on the tariff I was really on, it came within 0.4% of the real net bill over the year, but it imports about 8% and exports about 6% more than my Powerwall does.
A weather-only model (temperature and sunshine to demand and solar, R² 0.81 and 0.90) picks nearly the same dates, 18 Nov and 8 Feb, and its seven-day correlation with the full calculation is 0.90. I also look at fixed versus flexible Cosy with a £50 exit fee, which comes out dearer for me even with a forecast January rise.
Full write-up, charts, data and code (CC BY 4.0 / MIT): When to switch between Octopus Cosy and Intelligent Go: a year of data and a battery planner.
What I’d value this forum’s view on: how closely does a half-hourly planner like this match what your battery and heat pump really do, and what would you change in the assumptions?
I’m planning to build it into a free, open tool as the next step that will allow year-round cost comparison not just within the Octopus ecosystem but across suppliers - will there be enough interest in this, I wonder?
The code, daily data and charts are all in the open repo: GitHub - aiam-nano/home-energy-analysis: Open data and analysis from a year of solar, Powerwall, heat pump and EV energy use in Salford (Manchester), UK · GitHub
The battery planner and the weather model are in the switch_model folder, the rate history I used is data/tariff_rates_history.csv, and the method is written up in docs/. Data and charts are CC BY 4.0, code is MIT. If you run it on your own house and the results differ from mine, I’d like to hear how.
Interesting stuff.
I did a whole year analysis with Cosy a few years back (before they added the 3rd cheap period) where I simulated different battery charging/discharging strategies to see how Cosy compares to standard tariff and Agile.
My methodology was simpler, looking at historical consumption and solar generation and computing the import, export, charge and discharge for every hour to get the annual cost for each strategy. How does weather factor into your model?
Detail is in the substack post but it almost entirely tracks with weather
Thanks for sharing such a detailed year of data, it really helps to see how the trade-off changes with the seasons. The point about multiple cheap windows in winter versus a single overnight charge is especially useful for planning battery use. I would also keep an eye on how heat pump demand on the coldest days affects the balance, as that seems to be where the switching date matters most.
Your finding that the best tariff changes with the season makes sense, and it is a useful contrast with a fully hourly spot market. In Finland the day-ahead price changes every hour rather than in fixed cheap windows, so a planner would need to chase the cheapest individual hours instead of just choosing a switch date. Comparing how fortum sähkön hinta moves hour by hour shows why battery timing matters even more there, especially for heat-pump demand on cold evenings. Have you tried feeding hourly spot prices into the same planner to see how much of the seasonal effect is the tariff structure itself?
