SDM120 meters not being read
Hello,
Some will remember that I had a small struggle to connect the SDM120 meters to my emonPi. Thanks to a lot of help and handholding I got it work.
Unfortunately some time ago both meters stopped communicating. I don’t know what I’ve done wrong. I’ve looked at previous discussions about this and think I’ve tried all the suggestions.
This is the log message I get:
2025-02-02 10:43:27,373 ERROR SDM120 Could not read register @ 74: No communication with the instrument (no answer)
2025-02-02 10:43:28,391 ERROR SDM120 Could not read register @ 76: No communication with the instrument (no answer)
2025-02-02 10:43:28,491 ERROR SDM120 Could not read all registers
2025-02-02 10:43:28,492 INFO SDM120 Connecting to Modbus device=/dev/ttyUSB0 baud=2400 parity=none datatype=float
2025-02-02 10:43:31,099 ERROR SDM120 Could not read register @ 0: No communication with the instrument (no answer)
I’ve tried restarting, I’ve checked the code and it’s unaltered, the meters have the correct baud rate and id numbers, I’ve tried a different USB port, I’ve replaced the USB to RS485 adaptor…
So I’m stuck.
Here is the sdm120 config part:
[[SDM120]]
    [[[init_settings]]]
        device = /dev/ttyUSB0
        baud = 2400
    [[[runtimesettings]]]
        pubchannels = ToEmonCMS,
        read_interval = 10
        nodename = sdm120
        # prefix = sdm_
        [[[[meters]]]]
            [[[[[sdm120a]]]]]
                address = 1
                registers = 0,6,12,18,30,70,72,74,76
                names = V,I,P,VA,PF,FR,EI,EE,RI
                precision = 2,3,1,1,3,3,3,3,3
            [[[[[sdm120b]]]]]
                address = 2
Any suggestions? I’m sure it’s something trivial but I can’t see the wood for the trees.
Thanks,
Andrea
[Edited for presentation. Moderator (RW)]
Hi Andrea, Did you confirm that the cables are still secure?
The signal cable to the sdm120 is pretty fine. I had a few goes making up the Daisy-chain cable between my 4 sdm’s before I was happy with it.
Ah! I hadn’t thought of that - it may have got knocked as it’s a bit exposed. the power light on the RS485 adaptor is on, while the Tx light flashes periodically but rather weakly. I don’t know what the light actually mean, of course.
I would also check that this address hasn’t changed.
“rather weakly” – is this different to before? It might indicate a shorted Tx wire.
This is probably it, if you can connect via SSH please post the output of
ls /dev/serial/by-id/ -la
Instead of using device = /dev/ttyUSB0 it would be better to address the device directly to avoid this issue happening again e.g
device = /dev/serial/by-id/usb-1a86_USB_Single_Serial_xxxxxxx-xxxx
The address will be unique to your USB to Modbus adaptor. The command ls /dev/serial/by-id/ -la will show you the address of your adaptor.
OK. This is seriously embarrassing. I figured that in the end it must be the old “Is it plugged in? Is it switched on?” approach and took out all the wires. That’s wehn I spotted that the “A” wire was snapped right where it went into the terminal connection of the meter. It must have got yanked at some point.
When I put it all together again… sigh… it works.
I’ll never ask another question again for fear of wasting everyone’s time. Thanks for the many replies.
A
Don’t worry - those of us who’ve been in this game for a long, long time have been there and done that - more than once.
That’s the usual place where a wire will break, and first place to look.
Don’t you dare go away! You must stick around - if somebody else learns from your experience, some good has come from it.
