So I am attempting to install Home Assistant in docker on a fresh install on my emonPi running June18 release on an 8GB card. Once image was loaded, I performed the required sudo emonSDexpand.
On attempting to load in the HA install with Docker, I am getting disk full errors. /dev/root is at 97% use. File system looks like this:
>pi@emonpi(rw):/$ df -l
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 3491728 3202856 119784 97% /
devtmpfs 495480 0 495480 0% /dev
tmpfs 500088 0 500088 0% /dev/shm
tmpfs 500088 13028 487060 3% /run
tmpfs 5120 4 5116 1% /run/lock
tmpfs 500088 0 500088 0% /sys/fs/cgroup
tmpfs 30720 32 30688 1% /tmp
tmpfs 51200 10828 40372 22% /var/log
tmpfs 1024 4 1020 1% /var/lib/dhcp
tmpfs 40960 6724 34236 17% /var/lib/openhab
tmpfs 1024 4 1020 1% /var/cache/unbound
tmpfs 5120 0 5120 0% /var/lib/php/sessions
tmpfs 1024 0 1024 0% /var/tmp
tmpfs 1024 4 1020 1% /var/lib/dhcpcd5
/dev/mmcblk0p1 61384 23600 37784 39% /boot
/dev/mmcblk0p3 3744932 129649 3421939 4% /home/pi/data
tmpfs 100016 0 100016 0% /run/user/1000
So, my question is how do I free up some more space to get this loaded or is there a trick to push docker/HA in to the /home/pi partition?
Thanks.
