since we dont have the feedtime widgit on emoncms.org i wonder if a python script could be hammered up that would ask when a given feed/input was last updated and if more than 5 mins ago i could use that to turn on a LED to signal that something is going on
https://emoncms.org/feed/timevalue.json?id=
gives me: {“time”:1522144019,“value”:“22”}
what time format is that? unix of some sorts?
It’s JSON and the timestamp is Unix (seconds since 00:00 01/01/1970)
The Python time module uses the same format so time.time() - 1522144019 = seconds since last update.
Look at the Python json module to decode the reply into a Python dict which you can the access the values using their names eg reply[‘time’] and reply[‘value’].
oki, will be on it
this is just an alternative to not having the feedtime widget
first rough cut:
#!/usr/bin/env python
try:
# For Python 3.0 and later
from urllib.request import urlopen
except ImportError:
# Fall back to Python 2's urllib2
from urllib2 import urlopen
import json
import time
#this one is for the wiringpi lib
import wiringpi
# wiringpi numbers
wiringpi.wiringPiSetup()
wiringpi.pinMode(0, 1) # sets pin 0 to output (GPIO 17, Actual hardware pin number is 11) (Relay)
def get_jsonparsed_data(url):
Receive the content of ``url``, parse it as JSON and return the object.
Parameters
url : str
Returns
dict
response = urlopen(url)
data = response.read().decode("utf-8")
return json.loads(data)
url = ("https://emoncms.org/feed/timevalue.json?id=xxxx")
while True:
dif = time.time() - (get_jsonparsed_data(url))['time']
print dif
if dif > 60:
print 'Last update is more than 5 mins ago'
wiringpi.digitalWrite(0, 1) # sets port 0 to ON
else:
print 'Last update is less than 5 mins ago'
wiringpi.digitalWrite(0, 0) # sets port 0 to OFF
time.sleep(10)
