Hello,
My setup is made of Samsung EHS AE260RNWSEG/EU paired with AE040RXEDEG/EU.
I was wondering if someone has the firmware for AE040RXEDEG/EU (4kW) and AE060RXEDEG/EU (6kW). I wanted to compare them, see if I could somehow flash the 6kW version to the 4kW.
I believe the hardware is identical and the only difference is in EEPROM.
Also, if someone has a changelog / firmware list for both indoor/outdoor, that would be appreciated as well. For some reason with my current firmware the Waterpump PWM is reported as 2% even when it is off (?).
Outdoor:
Main Micom: DB91-02091B 190704
Inverter1 Micom: DB91-01930A 100007
EEPROM: DB82-04382A 190410
Indoor:
Main Micom: DB91-02103B 2304C8
Thank you,
Nicolae
