I’m wondering how to deal with daemons started at boot on emonSD.
Since it is raspbian based, it should be compatible with upstart.
So I tried to install upstart via apt-get, but I’m afraid of crashing my system.
Installation of upstart would lead to removal of the traditional “systemd-sysv”.
What is th eimpact? May I safely install upstart?
Thanks in advance,
TriCx
[email protected]:~$ sudo apt-get install upstart
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
cgmanager libcgmanager0 libjson0 systemd-shim
Suggested packages:
pm-utils graphviz upstart-monitor
The following packages will be REMOVED:
systemd-sysv
The following NEW packages will be installed:
cgmanager libcgmanager0 libjson0 systemd-shim upstart
0 upgraded, 5 newly installed, 1 to remove and 1 not upgraded.
Need to get 645 kB of archives.
After this operation, 2,319 kB of additional disk space will be used.
Do you want to continue? [Y/n]
