Howdy folks,
I am trying to run Feb 24 EmonSD on an EmonPi1, it doesn’t pickup Power 1 or Power 2.
It works perfectly with Oct 19 EmonSD.
Any guidance on how I can debug this?
Ray K
Howdy folks,
Ray K
Ultimately fixed this issue by reinstalling the firmware from Oct 19.
Did you do an import of data?
Most likely a configuration issue.
Oh, I’m sure it should; @TrystanLea care to comment?
If Trystan didn’t insist on making the images to fit a 16 GB SD card (IIRC), I could write one onto a 8GB and try that. But reducing the image is a right pain, and with every respect to Ray, I’m not driving down the road to buy a 32 GB card (the smallest I can get locally).
(This https://www.argos.co.uk/search/16gb-sd-card/ clearly doesn’t even understand the question
FWIW - I install the image on a brand 64gb
So it wasn’t lack of space that caused the issue.
