Hi, I’ve finally got the SIM900 talking to EmonCMS so I thought I would do the same for the WiFly module Again I’m following the application notes and failing Does anyone have any experience with this WiFi module and might be able to provide the Serial commands to do a GET ---- HTTP/1.0 to EmonCMS? I’m connected to the internet fine and have upgrade the firmware… these are the commands I’m using with the correct CR/LF etc but getting Error 400:
set ip proto 18
set dns name www.mydomain.com
set ip address 0
set ip remote 80
set com remote 0
open mydomain.com 80
GET /emoncms/input/post.json?json={power:200}&apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.0
The all important control characters are: CR Carriage Return (\r) & LF Line Feed (\n).
delay (500)
set ip proto 18
(CR)
(CR)
set ip address 0
(CR)
set ip remote 80
(CR)
set com remote 0
(CR)
(CR)
GET /emoncms/input/post.json?json={power:200}&apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx HTTP/1.1
(CR + LF)
Host: mydomain.com
(CR+LF)
(CR+LF)
Connection: close
(CR + LF)
Even shorter also works
delay (500)
set ip proto 18
(CR)
(CR)
(CR+LF)
Host: mydomain.com
(CR+LF)
(CR+LF)
