Room thermostat target value and flow target value logged simultaneously
Hi folks,
First of all, great job to the team behind this platform. This is such a useful and massive database of actual heatpumps in operation.
I am quite new to heatpump monitor and this is my very first question! I hope I have chose the right category for this question; otherwise, please let me know.
I have been playing with heatpumpmonitor API for a while to import data into Python, do basic analysis, perform visualization, etc. I have noticed that the signal logged under keyword 'heatpump_targetT" could be either the room target temperature (i.e., room setpoint), when there is a room thermostat, or flow target temperature (i.e, flow setpoint). I have not been able to find a system where both signals are logged simultaneously. Do you know if there is such a system? If so, what keywords are used? If not, what fundamentally prevents us from doing so? Having both signals logged at the same time can actually enable interesting applications and analyses.
Best regards,
Yash
For any data logged to EmonCMS you can easily log a number of different data with the same timestamp by including a ‘time’ value as an ISO Format string or in milliseconds.
{"power1":100,"power2":200,"power3":300,"time":ISO FORMAT}
Not sure if heatpump monitor is the same, but likely to be.
