RFM69Pi - Which Raspberry Pi is supported?
Hello,
after 10 years working, my emonBase stopped to work.
After multiple tests I realized the Raspberry Pi - Model B has gone.
In order to not throw away my emonTx V3 system I need to buy a new Raspberry Pi.
Which version of Raspberry is compatible with RFM69Pi that is used to connect with my emonTx V3 ? @Robert.Wall @TrystanLea
Btw this was the previous hardware fix (replaced original RFM12Pi V2 with current RFM69Pi - everything working at 868 MHz).
Thanks!
@TrystanLea will need to confirm this, but I believe any Raspberry Pi will still work with any emonCMS.
(I have a Pi 3 Model B running the Nov 22 with emonCMS 11.4.7 release of emonCMS.)
You must keep your 868 MHz RFM12Pi module to be able to receive from your existing emonTx V3 & emonTHs.
You will need to keep your SD card with emonCMS on it, and it should work with your present settings (i.e. emonhub.conf, Inputs processing, Feeds, Dashboards etc.). However, I recommend saving an image of the card before you use it again, if your computer has a card reader/writer. This will at least preserve all your data.
As this weekend and Monday is a holiday in the UK, Trystan might not answer for a few days.
