Paul - this is the log from Day 1 (right after starting with a new SD card and the current emonPi image).
It looks like it has always been this way. And I have done many, many reboots. I’ll try
restarting emonhub and reading thru the “thread is dead” posts.
2016-09-12 14:17:21,950 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz USA 1
2016-09-12 14:17:23,223 DEBUG RFM2Pi 4 NEW FRAME : OK 5 180 0 153 0 77 1 173 46 227 0 0 0 0 0 0 0 0 0 0 0 173 80 1 0 (-0)
2016-09-12 14:17:23,228 DEBUG RFM2Pi 4 Timestamp : 1473707843.22
2016-09-12 14:17:23,230 DEBUG RFM2Pi 4 From Node : 5
2016-09-12 14:17:23,231 DEBUG RFM2Pi 4 Values : [180, 153, 333, 119.49000000000001, 22.700000000000003, 0, 0, 0, 0, 0, 86189]
2016-09-12 14:17:23,233 INFO RFM2Pi Publishing: emon/emonpi/power1 180
2016-09-12 14:17:23,235 INFO RFM2Pi Publishing: emon/emonpi/power2 153
2016-09-12 14:17:23,237 INFO RFM2Pi Publishing: emon/emonpi/power1pluspower2 333
2016-09-12 14:17:23,240 INFO RFM2Pi Publishing: emon/emonpi/vrms 119.49
2016-09-12 14:17:23,242 INFO RFM2Pi Publishing: emon/emonpi/t1 22.7
2016-09-12 14:17:23,244 INFO RFM2Pi Publishing: emon/emonpi/t2 0
2016-09-12 14:17:23,246 INFO RFM2Pi Publishing: emon/emonpi/t3 0
2016-09-12 14:17:23,248 INFO RFM2Pi Publishing: emon/emonpi/t4 0
2016-09-12 14:17:23,250 INFO RFM2Pi Publishing: emon/emonpi/t5 0
2016-09-12 14:17:23,251 INFO RFM2Pi Publishing: emon/emonpi/t6 0
2016-09-12 14:17:23,253 INFO RFM2Pi Publishing: emon/emonpi/pulsecount 86189
2016-09-12 14:17:23,256 INFO RFM2Pi Publishing: emon/emonpi/rssi 0
2016-09-12 14:17:23,258 INFO RFM2Pi Publishing: emonhub/rx/5/values 180,153,333,119.49,22.7,0,0,0,0,0,86189
2016-09-12 14:17:23,260 INFO RFM2Pi Publishing: emonhub/rx/5/rssi 0
2016-09-12 14:17:23,263 DEBUG RFM2Pi 4 adding frame to buffer => [1473707843, 5, 180, 153, 333, 119.49000000000001, 22.700000000000003, 0, 0, 0, 0, 0, 86189]
2016-09-12 14:17:23,264 DEBUG RFM2Pi 4 Sent to channel' : ToEmonCMS
2016-09-12 14:17:36,167 DEBUG RFM2Pi 5 NEW FRAME : OK 5 180 0 160 0 84 1 98 47 227 0 0 0 0 0 0 0 0 0 0 0 173 80 1 0 (-0)
EDIT: here is the log after the emonhub restart
2016-10-25 18:42:51,499 INFO RFM2Pi Publishing: emonhub/rx/5/values 260,179,439,120.67,0,0,0,0,0,0,4745
2016-10-25 18:42:51,501 INFO RFM2Pi Publishing: emonhub/rx/5/rssi 0
2016-10-25 18:42:51,502 DEBUG RFM2Pi 6430 adding frame to buffer => [1477438971, 5, 260, 179, 439, 120.67, 0, 0, 0, 0, 0, 0, 4745]
2016-10-25 18:42:51,504 DEBUG RFM2Pi 6430 Sent to channel' : ToEmonCMS
2016-10-25 18:42:52,997 DEBUG MainThread SIGINT received.
2016-10-25 18:42:52,998 INFO MainThread Exiting hub...
2016-10-25 18:42:53,147 INFO MainThread Exit completed
2016-10-25 18:42:54,056 INFO MainThread EmonHub emonHub 'emon-pi' variant v1.1
2016-10-25 18:42:54,057 INFO MainThread Opening hub...
2016-10-25 18:42:54,058 INFO MainThread Logging level set to DEBUG
2016-10-25 18:42:54,059 INFO MainThread Creating EmonHubJeeInterfacer 'RFM2Pi'
2016-10-25 18:42:54,061 DEBUG MainThread Opening serial port: /dev/ttyAMA0 @ 38400 bits/s
2016-10-25 18:42:56,066 INFO MainThread RFM2Pi device firmware version & configuration: not available
2016-10-25 18:42:56,067 INFO MainThread Setting RFM2Pi frequency: 433 (4b)
2016-10-25 18:42:57,070 INFO MainThread Setting RFM2Pi group: 210 (210g)
2016-10-25 18:42:58,072 INFO MainThread Setting RFM2Pi quiet: 0 (0q)
2016-10-25 18:42:59,075 INFO MainThread Setting RFM2Pi baseid: 5 (5i)
2016-10-25 18:43:00,077 INFO MainThread Setting RFM2Pi calibration: 110V (2p)
2016-10-25 18:43:01,080 DEBUG MainThread Setting RFM2Pi subchannels: ['ToRFM12']
2016-10-25 18:43:01,081 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2016-10-25 18:43:01,082 DEBUG MainThread Setting RFM2Pi pubchannels: ['ToEmonCMS']
2016-10-25 18:43:01,083 DEBUG MainThread Interfacer: Subscribed to channel' : ToRFM12
2016-10-25 18:43:01,089 INFO MainThread Creating EmonHubMqttInterfacer 'MQTT'
2016-10-25 18:43:01,090 INFO MainThread MQTT Init mqtt_host=127.0.0.1 mqtt_port=1883 mqtt_user=emonpi
2016-10-25 18:43:01,093 DEBUG RFM2Pi 1 NEW FRAME : OK 5 255 0 186 0 185 1 175 47 0 0 0 0 0 0 0 0 0 0 0 0 138 18 0 0 (-0)
2016-10-25 18:43:01,095 DEBUG RFM2Pi 1 Timestamp : 1477438981.09
2016-10-25 18:43:01,097 DEBUG MainThread MQTT Subscribed to channel' : ToEmonCMS
2016-10-25 18:43:01,097 DEBUG RFM2Pi 1 From Node : 5
2016-10-25 18:43:01,099 DEBUG RFM2Pi 1 Values : [255, 186, 441, 12207, 0, 0, 0, 0, 0, 0, 4746, 0]
2016-10-25 18:43:01,100 DEBUG RFM2Pi 1 Sent to channel' : ToEmonCMS
2016-10-25 18:43:01,101 INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'emoncmsorg'
2016-10-25 18:43:01,103 DEBUG MainThread emoncmsorg Subscribed to channel' : ToEmonCMS
2016-10-25 18:43:01,202 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz USA 1
2016-10-25 18:43:01,203 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,305 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz USA 1
2016-10-25 18:43:01,307 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,409 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,514 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,611 DEBUG RFM2Pi acknowledged command: <nn> i - set node IDs (standard node ids are 1..30)
2016-10-25 18:43:01,617 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,715 DEBUG RFM2Pi acknowledged command: <n> b - set MHz band (4 = 433, 8 = 868, 9 = 915)
2016-10-25 18:43:01,721 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,819 DEBUG RFM2Pi acknowledged command: <nnn> g - set network group (RFM12 only allows 212, 0 = any)
2016-10-25 18:43:01,824 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:01,922 DEBUG RFM2Pi acknowledged command: <n> c - set collect mode (advanced, normally 0)
2016-10-25 18:43:01,928 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:02,026 DEBUG RFM2Pi acknowledged command: ...,<nn> a - send data packet to node <nn>, request ack
2016-10-25 18:43:02,031 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:02,129 DEBUG RFM2Pi acknowledged command: ...,<nn> s - send data packet to node <nn>, no ack
2016-10-25 18:43:02,133 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:02,244 INFO MQTT Connecting to MQTT Server
2016-10-25 18:43:02,250 INFO MQTT connection status: Connection successful
2016-10-25 18:43:02,251 DEBUG MQTT CONACK => Return code: 0
2016-10-25 18:43:02,253 DEBUG RFM2Pi acknowledged command: ...,<n> p - Set AC Adapter Vcal 1p = UK, 2p = USA
2016-10-25 18:43:02,355 INFO MQTT on_subscribe
2016-10-25 18:43:02,469 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz USA 1
2016-10-25 18:43:02,572 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz USA 1
2016-10-25 18:43:02,696 DEBUG RFM2Pi device settings updated: E i5 g210 @ 433 MHz USA 1
2016-10-25 18:43:02,802 DEBUG RFM2Pi 4 NEW FRAME : OK 5 0 1 181 0 181 1 142 47 0 0 0 0 0 0 0 0 0 0 0 0 139 18 0 0 (-0)
2016-10-25 18:43:02,807 DEBUG RFM2Pi 4 Timestamp : 1477438982.8
2016-10-25 18:43:02,808 DEBUG RFM2Pi 4 From Node : 5
2016-10-25 18:43:02,808 DEBUG RFM2Pi 4 Values : [256, 181, 437, 121.74000000000001, 0, 0, 0, 0, 0, 0, 4747]
2016-10-25 18:43:02,810 INFO RFM2Pi Publishing: emon/emonpi/power1 256
2016-10-25 18:43:02,812 INFO RFM2Pi Publishing: emon/emonpi/power2 181
2016-10-25 18:43:02,814 INFO RFM2Pi Publishing: emon/emonpi/power1pluspower2 437
2016-10-25 18:43:02,816 INFO RFM2Pi Publishing: emon/emonpi/vrms 121.74
2016-10-25 18:43:02,818 INFO RFM2Pi Publishing: emon/emonpi/t1 0
2016-10-25 18:43:02,820 INFO RFM2Pi Publishing: emon/emonpi/t2 0
2016-10-25 18:43:02,822 INFO RFM2Pi Publishing: emon/emonpi/t3 0
2016-10-25 18:43:02,824 INFO RFM2Pi Publishing: emon/emonpi/t4 0
2016-10-25 18:43:02,826 INFO RFM2Pi Publishing: emon/emonpi/t5 0
2016-10-25 18:43:02,829 INFO RFM2Pi Publishing: emon/emonpi/t6 0
2016-10-25 18:43:02,831 INFO RFM2Pi Publishing: emon/emonpi/pulsecount 4747
2016-10-25 18:43:02,833 INFO RFM2Pi Publishing: emon/emonpi/rssi 0
2016-10-25 18:43:02,835 INFO RFM2Pi Publishing: emonhub/rx/5/values 256,181,437,121.74,0,0,0,0,0,0,4747
2016-10-25 18:43:02,837 INFO RFM2Pi Publishing: emonhub/rx/5/rssi 0
2016-10-25 18:43:02,839 DEBUG RFM2Pi 4 adding frame to buffer => [1477438982, 5, 256, 181, 437, 121.74000000000001, 0, 0, 0, 0, 0, 0, 4747]
2016-10-25 18:43:02,840 DEBUG RFM2Pi 4 Sent to channel' : ToEmonCMS
2016-10-25 18:43:06,477 DEBUG RFM2Pi 5 NEW FRAME : OK 5 0 1 205 0 205 1 167 47 0 0 0 0 0 0 0 0 0 0 0 0 139 18 0 0 (-0)
2016-10-25 18:43:06,479 DEBUG RFM2Pi 5 Timestamp : 1477438986.48
20
