RFM12Pi replacement options
Back in 2014 I commissioned a Mk2 PV Router, EmonTx3 and 3 x EmonTHv2 all using 433Mhz RFM12B which Tx data to an Emoncms Raspberry Pi fitted with a RFM12Pi Rx. I have been using Emoncms.org for the past 10 years, but no longer need remote access so I would like to build up and test a local instance using another Raspberry Pi. What options do I have for Rx? The RFM69SPI is apparently incompatible so I’ll need another RFM12Pi. Am I right the later RFM69CW is compatible and may still be available? Thanks for any assistance.
Hello @porboynz has your current RFM12Pi stopped working? If you already have that and a RaspberryPi, that should be all that you need for a local instance?
You are right @TrystanLea however I would prefer to parallel build and test a local instance if possible and transition from emoncms.org once my current credit runs out in about 6 months.
