I’ve just had an emonPi2 installed with my Vaillant heat pump installation. I can enable and disable ssh with the push button but when I try to connect with putty using pi | emonpi2022, I get ‘access denied’.
Will creating an empty file named ssh in the root folder give me an initial login that doesn’t need a password?
Hello Nick, I’ve sent you the password in a PM
Many thanks Trystan, all working well.
Hi Trystan - I’m in exactly the same position, except looking at the docs it should be emonsd. Have tried every variation but no success.
The Heat Pump Monitor uses a different password entirely, and it’s not published. Support is included in the price you paid, so Trystan or someone from The Shop will be in touch as soon as they see this.
Or it might be on the last page of the printed instructions that came with your Heat Pump Monitor.
