Resetting my IotaWatt meter
My meter stopped working some time back. It reset back to default. However, it still connects to the WiFi network that I first connceted it to. I would like to reset it to its default settings using the following command
http://192.168.43.7/command?disconnect=yes as well as http://iotaWatt.local/command?disconnect=yes
I have the device is still connected with a sequence of Red Red Green instead of Red Green Green.
How can I troubleshoot this problem?
You have asked this question elsewhere.
I suggest The IoTaWatt forum is a better place to ask a question that is specifically about the operation and use of IoTaWatt. That is managed by Bob Lemaire, its creator, and he and the other users there are more likely to have the specific knowledge to help you.
The IoTaWatt forum uses the same software as this forum, but you must register a new account there. If the user name you have here is not taken, it might be helpful to have the same user name in both places.
If you post your question there, I’m sure he or somebody will get back to you quickly.
