Read smart meters (SML interface) with ESP and Tasmota and send data to emoncms
I recently stumbled across a very nice readout head for smart meters that can send data directly via wifi with an ESP running Tasmota:
Tasmota offers a smart meter interface for this purpose, which in combination with scripts allows the connection of almost any smart meter: Smart Meter Interface - Tasmota
In my case, I can use it to read out the total grid consumption, feed-in and the current power, but it depends on the individual smart meter, which data are accessible via SML interface.
The Scripting Language of Tasmota (Scripting Language - Tasmota) makes it super easy to process the data and send it to any web server. Here is an example to send the data directly to an emoncms instance (emoncms.org works too).
>D
url="[emoncms.org]"
key="xxx"
>B
=>sensor53 r
>S
dp4
if upsecs%10==0
and *sml[1]* != 0
then
=>WebSend %url%/input/post?node=SML&fulljson={"Power":%sml[3]%,"Grid":%sml[1]%,"Feedin":%sml[2]%}&apikey=%key%
>M 1
+1,3,s,16,9600,SML
1,77070100010800ff@1000,Energie,kWh,energy,4
1,77070100020800ff@1000,Lieferung,kWh,en_out,4
1,77070100100700ff@1,Leistung,W,power,2
1,7707010060320101@#,SID,,meter_id,0
Just add your apikey and the suitable script part for your smart meter, that’s it.
@TrystanLea and @glyn.hudson Maybe this would be a nice addition to your webshop? Smart meters are steadily spreading and the beauty of it is that it all works without any work on the electrical system.
Actually, you are reading the LED Pulse that was available long before smart meters, so it really has nothing to do with Smart Metering. I’ll edit the title so as not to confuse.
There is a pulse reader in the shop, but that requires a separate device to detect the pulse. This does look like a good solution! Thanks.
[edit]
Perhaps I misunderstood, does this device have builtin Wi-Fi/ESP chip?
Have you a link to it?
It’s not about reading out the LED, I know the article from the store, have also tested it myself. The read/write head uses the infrared interface which speaks either SML or OBIS. So the actual meter and power values are transmitted instead of the pulses.
Here is a link to the webshop:
I think it`s a really fancy device for just 34 €.
Could be a nice addition to the OpenEnergyMeter product portfolio, in my opinion.
In the UK?
[edit]
I suspect this is for European meters. AFAIK UK meters do not have an IR interface but use encrypted Zigbee for the HAN.
I believe some do have an IR interface, but it too is encrypted (presumably so that the meter owner can charge you to get your own data back via their website. :roll_eyes:)
An easy way to feed UK smart meter data into emoncms is to use the Glowmarkt Display and CAD . It connects to a SMETS2 or SMETS1 smart meter using Zigbee and can be configured to push the data over Wi-Fi using MQTT. I use nodered to re-format the data for emoncms so I can display both the import and export meter readings with a resolution of 1wH as well as getting a real time power feed. They also have a smartphone app and APIs which allow you to pull historic data from their web site
Yes, I do exactly the same.
Nice find @Simsala! and thanks for sharing how to do this. Wow looks like quite a long list of supported meters on there, definitely one for us to look into in more detail.
Hi, i am running emoncms lokal on my pi. I use solpiplog to trakc my 3 inverters. Is it also possible to add the Tasmota sensor to emoncmcs? Iam a complette newby on this field.
Thnak you
thanks for sharing Your scripts. I try to send results from the tasmota device smart meter reader (You are using) to the emoncms localy installed on an raspberry (http://192.168.178.25) via wlan.
How to du that? Can You give me some hint to the Tasmota scripting.
Uwe
Hi Uwe,
actually it should be enought to replace emoncms.org with your IP Adresse (keep the brackets […], they are part of the tasmota scripting kanguage. Do you have the same smart meter? It‘s important to unlook it with a pin, which i got from my dso.
Hi Elias,
I am always enthusiastic to get a quick response after such a long time. Thanks a lot.
Yes, i am using the same device and it is unlocked with a pin.
I will give You a response
Solved. Many Thanks
Uwe
