Hello,
I’m looking for a way to read PV output data from the websites of the inverter manufacturers.
So many inverters now include a web-interface and access to data on the manufacturer’s website.
I’ve seen API’s from some manufacturers that make it relatively easy to retrieve daily/weekly/monthly data for installations.
Is there anyway to “plug” these datasources into EmonCMS ?
I can imagine writing an external script that gets the data using the inverter API and then writes to EmonCMS using the EmonCMS API but it would lovely if all that could be managed “inhouse”.
I do realise that this removes the emonpi/emontx from the loop for the PV side of things and that this may not be desirable.
Best regards /Colm
