My GSHP emonpi has been running well for about 3 years. Now adding solar PV and battery storage to the home and need to tidy up wiring.
One issue that’s always been a problem is >10m cable runs from DHW tank temperature sensors via terminal block back to the emonpi. Erroneous data spikes have been attributed to length of cable.
Note: the DHW tank is in the house, and Kensa GSHP in an outbuilding, as is the 19" rack holding emonpi, internet router and switch.
Now wondering if it makes sense to put an Arduino-type device at the DHW cylinder to carry sensor data over LAN? Ideally, Arduino (or similar) would be PoE so I can simply have one RJ45 connecting it to the LAN, and the two sensors neatly running less than a metre on the tank itself.
Any advice appreciated. thanks
