I was originally introduced to emoncms with my openevse. I already had a rainforest eagle collecting data from my home energy use, but didn’t know how to get the data up to the emoncms cloud to log.
That is the one. Its had its ups and downs, I purchased it a couple of years ago, but its been pretty stable since they moved to cloud based storage about a year or so ago.
I have the same device but an older version purchased in June 2016. Mine is the RFA-Z109.
I set it up with the Node-RED flow Rainforest Eagle Smart Meter API by Mike Thompson. As Bobby said it has its up & downs. The Rainforest Eagle data is stored on an emonPi.
Node-Red…not sure where I’ve been that I hadn’t found out about Node-Red until your post.
What a powerful tool. I already put up an MQTT server with a Smartthings bridge and realized I can pull ALL KINDS of data in, manipulate it and push it up to emoncms.
That’s almost exactly what I do also! (I don’t have smartThings). I grab the local weather, my ecobee thermostat, and my Rainforest Eagle and others with Node-RED. Have fun!
Hello Bobby… what did you use to send Smartthings data to the MQTT Broker? I am looking for something to send to a Broker when something is switched on/off in my Smartthings, to read it in my Emoncms. Thanks.
