Hi all,
Here’s a script that will take values from your feeds and push them to PVOutput.org
Enjoy
<?php
#Global Variables
// pvoutput API key here; OLD
//$Feed_api_key = '091119xxxxxxxxxxxxxxxxxxxx4eb3ca';
$PV_api_key = '3c4a95xxxxxxxxxxab8007c';
// PVOutput.orgSystem ID here
$SystemID = '12345';
//EMONCms Local IP Here
$EMONCms_Local_IP = "192.168.15.208";
//EmonCMS Read API Key Here
$EmonCMS_Read_API_Key = "091119xxxxxxxxxxxxxxxxb3ca";
//Add CronTab Job once complete - */5 * * * * /usr/bin/php -q /home/pi/SCRIPT_NAME.php > /dev/null
$url = "https://pvoutput.org/service/r2/addstatus.jsp";
$json_tpower = file_get_contents("http://192.168.15.208/feed/list.json?apikey=".$EmonCMS_Read_API_Key);
$jsonToArray = json_decode($json_tpower, true);
//Verify if feed source come with empty data
if(empty($jsonToArray)){
exit();
//Array which The PVOUTPUT variables will be populated
$variables = [];
date_default_timezone_set('Australia/Melbourne');
$timezone = date_default_timezone_get();
$date = date('Ymd');
$time = date('H:i');
//Adding Time and Date in variables
$variables["d"] = $date;
$variables["t"] = $time;
//The following values next to 'case' are the names of data feeds within EmonCMS
//Line 54/V4 - This is current power usage
//Line 58/V2 - Solar production in watts
//Line 61/V6 - Voltage
//Line 64/V7 - Extended data - optional and can be deleted.
//Line 67/V7 - Extended data - optional and can be deleted.
//Line 70/V7 - Extended data - optional and can be deleted.
//Line 73/V7 - Extended data - optional and can be deleted.
foreach($jsonToArray as $key => $Feed_value){
switch ($Feed_value["name"]) {
case 'use':
$variables["v4"] = $Feed_value["value"];
break;
case 'solar':
$variables["v2"] = $Feed_value["value"];
break;
case 'vrms':
$variables["v6"] = $Feed_value["value"];
break;
case 'CarPort':
$variables["v7"] = $Feed_value["value"];
break;
case 'Roof':
$variables["v8"] = $Feed_value["value"];
break;
case 'Air Con':
$variables["v9"] = $Feed_value["value"];
break;
case 'price':
$variables["v10"] = $Feed_value["value"];
break;
case 'use':
// code...
break;
$curl = curl_init($url);
curl_setopt($curl, CURLOPT_URL, $url);
curl_setopt($curl, CURLOPT_POST, true);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, true);
$headers = array(
"X-Pvoutput-Apikey: ".$PV_api_key,
"X-Pvoutput-SystemId: ".$SystemID,
"Content-Type: application/x-www-form-urlencoded",
curl_setopt($curl, CURLOPT_HTTPHEADER, $headers);
//Build the query text to be sent in CURL
$data = http_build_query($variables);
curl_setopt($curl, CURLOPT_POSTFIELDS, $data);
//for debug only!
curl_setopt($curl, CURLOPT_SSL_VERIFYHOST, false);
curl_setopt($curl, CURLOPT_SSL_VERIFYPEER, false);
$resp = curl_exec($curl);
curl_close($curl);
var_dump($resp);
Edit - munged API keys. Moderator, BT
