Pushing to an SSL InfluxDB instance
Does IotaWatt support SSL InfluxDB? It doesn’t seem to.
Cheers,
Mike
Sorry Mike, not enough heap for that with the standard ESP HTTPclient support.
I’m working on a lite HTTP layer to drop onto the ESPasyncTCP which supports a lightweight TSL implementation. That’s probably quite a few months away, if it works at all (the TLS that is, the asynchronous does work fine).
If that doesn’t do it, I expect an ESP32 port will solve the issue. That’s probably a year off.
Thanks for the reply Bob, that makes sense. I guess I could proxy the responses via nginx or something to my HTTPS instance.
