Pulse width: 100-300 ms
Pulse weight: 0.1 kWh/pulse, 1.0 kWh/pulse
recommended
I am looking for pulse detector with pulse out .Which model is recommended?
Best Regars
Andrew
recommended
Best Regars
Andrew
Welcome, Andrew, to the OEM forum.
I’m afraid you assume we know as much as you do about your system, unfortunately all we know is what you’ve written. Please take a look at the FAQ page (there’s a link at the top of this page) and the section a few paragraphs down “Asking for help”.
Tell us a bit more about the pulse and where it comes from, and where you want to send it, and then somebody here can help you.
Dear @Robert.Wall .Sorry for unclear question. I would like to read pulse signal from Schneider Energy Meter Pluse LED and integrate into my Mitsibishi AE-200 Central Air Conditioning controller. Our AE-200 just recommend [Pulse width: 100-300 ms ,Pulse weight: 0.1 kWh/pulse, 1.0 kWh/pulse]. I just would like to know that OEM can read from Schneider Electric Energy Meter and output pulse to My AE-200 controller?
Best Regards
Andrew
Looking at the Technical Manual AE-200E Technical Manual - Document Library - Mitsubishi Electric, Fig 4.1 (page 34), it appears that you also need a “P1 Controller” and a 24 V power supply to interface to your AE-200. This https://planetaklimata.com.ua/instr/Mitsubishi_Electric/Mitsubishi_Electric_PAC-YG60MCA-J_INSTALLATION_MANUAL_Eng.pdf MIGHT be the correct device. Unfortunately, I do not know of a suitable optical pulse detector which will work at 24 V d.c. Our optical pulse detector for use with our emonPi only works between 3.3 V and 5 V.
My best advice to you is to contact a local heating engineer who is familiar with Mitsubishiheating controllers.
I’m sorry I cannot help you further.
