Processing power values
Good afternoon, I have a (maybe) simple question and need your help.
I would like to create a feed, where I can directly see the money savings due to the usage of the solar power I generate. Therefore, I need to do some calculation with the used / produced energy per day.
In the first step, I produced the kWh/d with the related operation out of the power feeder. Afterwards I would like to do some mathematical operation to calculate my personal used energy and finally to multiply with a factor to generate my saved value in Euro.
Unfortunately, I can’t take the kWh/d for further calculations. Does anybody has a tip for me, how I can calculate with the kWh/d values?
Many thanks in advance.
Your kWh/d is a new feed?
You have an input process + feed, but that adds the value passed down the processes and the value in the feed. There’s also a Reset to ZERO process.
You need at the end of the processes you have:
Reset to ZERO
+ feed
and then do the maths you had in mind. You have × +, then there are the conditionals and GOTO which allow simple branching.
Dear Robert,
many many thanks for your advise. It works perfect!!!
Greetings, Thomas
