Problems Running emonCMS Behind Reverse Proxy with SSL on Separate Raspberry Pi
I have several Raspberry Pi web servers running various things, including one that runs emonCMS (emonSD-26Oct17 version). I’d like to set up a reverse proxy behind my home router, running on a dedicated Raspberry Pi that can route traffic to the correct Pi based on domain. Thus I’d like to be able to run emonCMS behind a reverse proxy running on a different machine.
I have had success doing this with both NGINX and Apache2 running the reverse proxy, as long as I stick with http. As soon as I try to enable SSL I get results that suggest to me that emonCMS can no longer parse the inbound URL to find which script it should run.
Here is what I see:
Here is the VirtualHost I am running. Can anyone help?
<IfModule mod_ssl.c>
    <VirtualHost _default_:443>
            ServerAdmin webmaster@localhost
            DocumentRoot /var/www/html
            ErrorLog ${APACHE_LOG_DIR}/error.log
            CustomLog ${APACHE_LOG_DIR}/access.log combined
            SSLEngine on
            SSLCertificateFile       /etc/letsencrypt/live/baldockery.net/fullchain.pem
            SSLCertificateKeyFile  /etc/letsencrypt/live/baldockery.net/privkey.pem
            ProxyPass / http://192.168.0.100/
            ProxyPassReverse / http://192.168.0.100/
            ServerName baldockery.net
    </VirtualHost>
In addition to your normal settings I use:
            ServerName abc.xyz.org
            UseCanonicalName On
            SSLProxyEngine On
            ProxyPreserveHost On
            ProxyRequests Off
            RequestHeader set X-Forwarded-Proto "https" env=HTTPS
            ProxyPass /emoncms http://emonpi/emoncms
            ProxyPassReverse /emoncms http://emonpi/emoncms
Some of the above may be for the other sites behind my proxy, like node-red, the mqtt relay etc.
I don’t recall changing anything on the emonpi, but…
That worked. Thank you!
Another question. Did you have any luck putting node-red behind a reverse proxy with SSL? I haven’t been able to. It seems like the socket connection gets lost.
You need to forward the web socket, ala:
            ProxyPass /nodered/comms wss://emonpi:1880/comms
            ProxyPassReverse /nodered/comms wss://emonpi:1880/comms
            ProxyPass /nodered https://emonpi:1880
            ProxyPassReverse /nodered https://emonpi:1880
if you want an easier setup than NGINX, have a look at caddy https://caddyserver.com/ uses letsencrypt automatically and the config files are much simpler
Except all the above is Apache…
Now the reverse proxy works and stays connected, but it never asks for a password. It seems like the socket between the reverse proxy and the node-red server has been authenticated and now it doesn’t ask for it again. Maybe it is better to move authentication to the reverse proxy server? Or I need to forward more information from the reverse proxy to the node-red server?
More detail …
This worked. I did need to enable ws_tunnel for it to work.
sudo a2enmod proxy_wstunnel
I also needed to change “wss” to “ws”, since I’m not running SSL on the node-red server itself, so the communication from the reverse proxy to node-red is over ws, not wss.
ProxyPass /comms ws://192.168.1.25:1880/
ProxyPassReverse /comms ws://192.168.1.25:1880/
ProxyPass / http://192.168.1.25:1880/
ProxyPassReverse / http://192.168.1.25:1880/
Thanks. I’ll check that out, too.
I just thought I’d mention I have a similar set up working.
I’m using emonCMS from a docker container and I want to proxy it from a sub-path in my existing Apache server.
I had a fair amount of trouble but nothing too unusual.
I can confirm that if you want emonCMS to spit out “https” URLs you need the:
RequestHeader set “X-Forwarded-Proto” “https”
because mod_proxy doesn’t add that by default. “core.php” will use that header.
I had a problem where emonCMS in the Docker container is running at “/” and many of the generated URLs ended up hitting the root of my web server so that was bad.
I used this hack to fix it.
First of all I stopped mod_proxy including the host forwarding header using this blunt instrument (because unset didn’t work):
ProxyAddHeaders Off
Then I added this abomination:
RequestHeader set “X-Forwarded-Host” “example.com/some/sub-path”
so that when core.php writes the URLs they include the sub-path I’m using on my Apache server. Without this it just appends the simple “script path” to the host name.
Finally, I already has Basic auth on the web server and so that was getting passed down and causing “Invalid Key” because it wasn’t valid in emonCMS.
I was able to stop it passing through like this:
RequestHeader unset Authorization
and now I have to login to emonCMS and it creates a session cookie which is good.
Hope that helps someone one day.
David Bowen
