I am trying to download feed data from the local emonCMS as a CSV file. I have tried both UNIX date time format and Excel, with the same results.
When I open the .csv file, I see the following
<br />
<b>Warning</b>: Trying to access array offset on value of type null in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>851</b><br />
<br />
<b>Warning</b>: Undefined array key 0 in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>854</b><br />
<br />
<b>Warning</b>: Trying to access array offset on value of type null in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>854</b><br />
<br />
<br />
<br />
<br />
null null null
<br />
<b>Warning</b>: Undefined array key 1 in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>851</b><br />
<br />
<br />
<b>Warning</b>: Undefined array key 1 in <b>/var/www/emoncms/Modules/feed/feed_model.php</b> on line <b>854</b><br />
<br />
<br />
<br />
<br />
<br />
null null null
The data is there as I can see it when I go to the graphs page, but the timeframe I want to download is too large for the graphing page.
Not sure how to overcome the errors on the Feeds download to be able to download the data.
I just tried to download the same data from emoncms.org and received a different error message
request datapoint limit reached (20000), increase request interval or reduce time range, requested datapoints = 51840
Any suggestions are greatly appreciated.
Thank you.
