Problem with missing data on graph
23.pdf (347.9 KB)
I have attached a file showing a graphing problem from my emonTH V2. config and log are also included.
First, I realize that I have a very weak signal from the unit to the emonBase. However, the temperature seems to be coming through and being graphed (more or less), while the humidity is only shown in small sections of the graph and is missing most of the data (show missing data checked). The log portion shows that humidity data is being received every 60 seconds even though it’s not being graphed most of the time.
Since I’m very new at this, I may be overlooking something obvious. Thanks for any help.
Bob
