I had been running emoncms successfully for several years and recently upgraded from buster to bookworm and 32 bit to 64 bit. I did a fresh install but migrated over my mariadb data and /var/www and /opt/emoncms and opt/openenergymonitor directories. I had problems with redis that I believe may have been down to permissions in that it kept crashing.
However, I now have issues where in the apache logs I keep seeing a bunch of lines with PHP warnings (an example below) and the website never pulls back feeds or inputs. If I disable redis it works fine.
[Thu Feb 22 22:13:50.232432 2024] [php:warn] [pid 13643] [client 10.192.168.197:61456] PHP Warning: Undefined array key "description" in /var/www/html/emoncms/Modules/input/input_model.php on line 373, referer: http://10.192.168.198/emoncms/input/view
[Thu Feb 22 22:13:50.232782 2024] [php:warn] [pid 13643] [client 10.192.168.197:61456] PHP Warning: Cannot modify header information - headers already sent by (output started at /var/www/html/emoncms/Modules/input/input_model.php:373) in /var/www/html/emoncms/index.php on line 316, referer: http://10.192.168.198/emoncms/input/view
[Thu Feb 22 22:13:50.235239 2024] [deflate:debug] [pid 13643] mod_deflate.c(869): [client 10.192.168.197:61456] AH01384: Zlib: Compressed 12817 to 1249 : URL /emoncms/index.php, referer: http://10.192.168.198/emoncms/input/view
[Thu Feb 22 22:13:54.646102 2024] [mpm_prefork:notice] [pid 13641] AH00170: caught SIGWINCH, shutting down gracefully
before posting here, I decided to upgrade as I hadn’t upgraded in some time, that seemed to work ok using init.sh
Components: Emoncms Core v10.8.1 | App v2.1.6 | Dashboard v2.1.4 | Device v2.1.2 | Graph v2.1.1 | Backup v2.3.3 | Network v3.1.2 | Postprocess v2.4.7 | Sync v2.1.5 | Usefulscripts v2.3.11 | EmonScripts v1.7.10
Tbh, at this point I’d be willing to drop the data in the redis files, but I would want to keep my inputs and rule processing. I tried looking to see where the system knows what redis files to look for but couldn’t find it anywhere.
Any suggestions on how I get back to a working emoncms system?
Thanks.
