new to this and just wondered if the emoncms when used to monitor a solar pv system has the ability to POWER DOWN after power output from pv system is ‘down for the day’?
also if it has the ability to POWER ON when the pv system begins generating power?
No, it’s designed to run continuously. Although the software has been set up as far as possible to avoid problems with corrupted SD cards, unless you do a controlled shutdown, you are liable to corrupt the SD card, possibly leading to it becoming unusable. Indeed, many of our users recommend using a UPS for that reason.
Isn’t that essentially the same as a UPS, provided of course that you keep it charged?
The point I was trying to make is that a sudden withdrawal of power isn’t good for the SD card, which is what I anticipated you’d do if you somehow powered your Pi only when the sun was up. And I wasn’t considering the holes in the data you’d have overnight. If you go on to the arrangement you envisage here, you’ll need the emonPi to be permanently powered anyway, or you wouldn’t (of course) have any consumption data overnight.
Here’s a previous discussion about “UPSs” for the Pi
There’s plenty of good options available now. The main thing to look out for is that it will supply power from the mains adapter when available and flip to the battery when it is not available. A lot of similar adapters from eBay etc. will either charge the battery, or supply power, but not both.
It depends on how long you want it to run for. If the power is off, it will eventually run out. For me I use an APC 750VA UPS to run all my network gear and the Pi I currently have running HA (soon to move to Proxmox on a Laptop so built-in UPS). For me, a UPS is partly about surge protection as well although the UPS is plugged into a surge protection power strip (belt & 2 sets of braces).
i am new to rpi but have looked at this technology with curiosity. it seems to really shine in dedicated systems applications, like the one here emoncms.
That type of battery is designed to put out a large amount of current for a short time,
typically 30 to 60 seconds. As such, it won’t last very long before it “goes dead.”
(that’s why your car won’t start the morning after you find you left the dome light on the night before)
If you don’t need a “long term” solution, the mower battery would work fine. By long term, I mean
more than just a few hours. e.g. overnight, or a full day or more.
Ideally, you’ll want a battery designed to put out a comparatively smaller amount of current for a much longer interval. Deep Cycle Marine batteries come to mind here, but they fare only a bit better than the
“starting” batteries do. A trolling motor (fishing) battery would be a better choice. Golf cart batteries
would be even better yet.
I bought a USB DC-DC converter similar to the one you linked to:
but it was a disappointment. With 13.8 V at the input, the output was ~4.5 V.
That was with a 1 Amp load, which according to the device’s spec, should’ve been no problem.
