Good morning.
I have just moved an emonpi and emontx from a house where it was recording and showing feed data from 2 clip on probes very successfully.
In the new location I have deleted the old data files and set up the new installation on 2 clip on probes. The installation process goes very well but the refresh feed size produces no change in feed size.
Instantaneous power values are shown and when I try and download the data for each feed the screen shows a probable file size but when the files are saved they are empty.
I should say that the Pi was shut down brutally in the old location but appeared to restart OK in the new location.
Where should I start looking?
Regards
Chris
Here is the emonhub log…
2016-06-09 05:57:50,839 INFO RFM2Pi Publishing: emonhub/rx/8/values 503,3,0,0,5.27,300,300,300,300,300,300,1
2016-06-09 05:57:50,842 INFO RFM2Pi Publishing: emonhub/rx/8/rssi -60
2016-06-09 05:57:50,844 DEBUG RFM2Pi 6152 adding frame to buffer => [1465451870, 8, 503, 3, 0, 0, 5.2700000000000005, 300, 300, 300, 300, 300, 300, 1, -60]
2016-06-09 05:57:50,845 DEBUG RFM2Pi 6152 Sent to channel' : ToEmonCMS
2016-06-09 05:57:52,806 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 157 162 208 65 248 3 201 3 135 240 90 98 244 116 144 108 205 151 230 225 121 (-104)
2016-06-09 05:57:53,426 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 16 185 5 153 247 5 49 36 121 56 91 67 245 15 103 159 120 163 85 158 52 (-102)
2016-06-09 05:58:00,150 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 138 201 49 210 191 6 75 62 179 14 104 203 122 118 12 161 238 219 182 223 24 (-104)
2016-06-09 05:58:00,255 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 19 240 43 164 24 55 249 134 140 178 155 193 156 245 170 26 2 94 28 129 128 (-103)
2016-06-09 05:58:00,361 DEBUG RFM2Pi 6153 NEW FRAME : OK 8 250 1 1 0 0 0 0 0 16 2 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-63)
2016-06-09 05:58:00,364 DEBUG RFM2Pi 6153 Timestamp : 1465451880.36
2016-06-09 05:58:00,364 DEBUG RFM2Pi 6153 From Node : 8
2016-06-09 05:58:00,365 DEBUG RFM2Pi 6153 Values : [506, 1, 0, 0, 5.28, 300, 300, 300, 300, 300, 300, 1]
2016-06-09 05:58:00,365 DEBUG RFM2Pi 6153 RSSI : -63
2016-06-09 05:58:00,366 INFO RFM2Pi Publishing: emonhub/rx/8/values 506,1,0,0,5.28,300,300,300,300,300,300,1
2016-06-09 05:58:00,368 INFO RFM2Pi Publishing: emonhub/rx/8/rssi -63
2016-06-09 05:58:00,369 DEBUG RFM2Pi 6153 adding frame to buffer => [1465451880, 8, 506, 1, 0, 0, 5.28, 300, 300, 300, 300, 300, 300, 1, -63]
2016-06-09 05:58:00,370 DEBUG RFM2Pi 6153 Sent to channel' : ToEmonCMS
2016-06-09 05:58:09,841 DEBUG RFM2Pi 6154 NEW FRAME : OK 8 243 1 1 0 0 0 0 0 24 2 184 11 184 11 184 11 184 11 184 11 184 11 1 0 0 0 (-61)
2016-06-09 05:58:09,845 DEBUG RFM2Pi 6154 Timestamp : 1465451889.84
2016-06-09 05:58:09,846 DEBUG RFM2Pi 6154 From Node : 8
2016-06-09 05:58:09,846 DEBUG RFM2Pi 6154 Values : [499, 1, 0, 0, 5.36, 300, 300, 300, 300, 300, 300, 1]
2016-06-09 05:58:09,847 DEBUG RFM2Pi 6154 RSSI : -61
2016-06-09 05:58:09,848 INFO RFM2Pi Publishing: emonhub/rx/8/values 499,1,0,0,5.36,300,300,300,300,300,300,1
2016-06-09 05:58:09,850 INFO RFM2Pi Publishing: emonhub/rx/8/rssi -61
2016-06-09 05:58:09,852 DEBUG RFM2Pi 6154 adding frame to buffer => [1465451889, 8, 499, 1, 0, 0, 5.36, 300, 300, 300, 300, 300, 300, 1, -61]
2016-06-09 05:58:09,853 DEBUG RFM2Pi 6154 Sent to channel' : ToEmonCMS
2016-06-09 05:58:13,772 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 158 125 123 45 236 125 81 246 45 170 121 64 215 237 83 115 28 240 15 186 200 (-101)
2016-06-09 05:58:13,877 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 173 207 97 255 114 52 86 220 74 163 79 51 225 238 240 74 238 134 175 153 209 (-103)
2016-06-09 05:58:16,190 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 165 116 101 186 151 46 123 246 18 223 29 12 102 25 186 227 192 127 0 42 204 (-100)
2016-06-09 05:58:19,340 DEBUG RFM2Pi Discarding RX frame 'unreliable content'? 8 243 1 1 0 0 0 0 20 2 184 11 184 11 184 11 184 11 184 11 184 (-59)
