I’ve read the Guide carefully but am having a problem …
I have an emonTx serially connected to an RPi3+ (running June 2018 beta image). It works fine - I can see an input and create a feed - IP=192.168.0.69.
I have a second RPi3+ (also running June 2018 beta image). It does not and will not have an emonTx connected (not its purpose). I can access it on my local network - IP=192.168.0.208.
I’m trying to post data from emoncms (192.168.0.69) to emoncms (192.168.0.208) using the following Interfacer per the Guide …
[[watchman_emoncms]]
[[[init_settings]]]
[[[runtimesettings]]]
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
url = https://192.168.0.208/emoncms
apikey = 198bc892e4dca583b14a9ef51fa2ec32
senddata = 1 # watchman_emoncms
sendstatus = 0 # Enable sending WAN IP to Emoncms MyIP (requires My IP installed)
sendinterval = 10 # Bulk send interval to post in seconds
The EmonHub log suggests that this is correctly established …
INFO MainThread Creating EmonHubEmoncmsHTTPInterfacer 'watchman_emoncms'
DEBUG MainThread Setting watchman_emoncms subchannels: ['ToEmonCMS']
DEBUG MainThread Setting watchman_emoncms pubchannels: ['ToRFM12']
INFO MainThread Setting watchman_emoncms url: https://192.168.0.208/emoncms
INFO MainThread Setting watchman_emoncms senddata: 1
INFO MainThread Setting watchman_emoncms apikey: set
INFO MainThread Setting watchman_emoncms sendstatus: 0
I used the apikey from the Account page for emoncms (192.168.0.208) … the first one listed & described as Write
Then there’s a problem as the log shows …
INFO watchman_emoncms sending: https://192.168.0.208/emoncms/input/bulk.json?apikey=E-M-O-N-C .... etc with a whole bunch of data
WARNING watchman_emoncms watchman_emoncms couldn't send to server, URLError: [Errno 111] Connection refused
WARNING watchman_emoncms send failure: wanted 'ok' but got ''
Any suggestions would be most helpful - thanks
Could it be a problem with the June 2018 beta image?
Does emoncms (192.168.0.208) ‘the receiver’ require a special Interfacer?
John Banks
