I am running EmonCMS on a separate RPi (192.168.60.6). Now I want to post several values from my feeds to my already running MQTT broker running on a different RPi (192.168.60.5)
My broker is working correctly. It receives data from my EmonESP and some other ESP’s.
I configured my emoncms/settings.php:
//3 #### MQTT
// The 'subscriber' topic format is rx/* - where * is the emoncms input node number.
// The 'publisher' topic format is user selectable from the 'Publish to MQTT' input process, for example power/solar
$mqtt_enabled = true; // Activate MQTT by changing to true
$mqtt_server = array( 'host' => '192.168.60.5',
'port' => 1883,
'user' => '',
'password' => '',
'basetopic'=> '/emon',
'client_id' => 'emoncms'
My broker does not require username or password. I added “publish to MQTT” in my process list
but unfortunately my broker doesn’t get any data on /emon/emoncms/#
I don’t know where to look
