Forgive me if this has been asked before, I’ve tried searching and couldn’t find anything!
Is it possible to post data to multiple emonCMS instances from my emonPi? I have my data going to my own server, but I’d also like it going to emoncms.org.
Yes, look at emonhub.ini - it’s all in there (and it has been asked before - your Search-Fu has failed you )
Gah! I’ll take a look, thanks. I found a lot about multiple emon’s posting to a single emonCMS, but mine is the other way round.
Oooookay, so I found it in the end. Ended up reading the code. I had originally tried exactly what I needed to work, but maybe it didn’t save properly. I had duplicated the emoncms.org EmonHubEmoncmsHTTPInterfacer config block, changed names, URL & api key, but after I saved the second one disappeared, so I assumed there was something wrong with that.
I must have done something a bit wrong.
Anyhow, @Robert.Wall, I’m happy to add this to some documentation somewhere. I seriously couldn’t find any after searching. Any thoughts on where I could add it?
Did you see emonhub/configuration.md at emon-pi · openenergymonitor/emonhub · GitHub ?
and Posting locally and to emoncms.org? | Archived Forum ?
Yes, but correct me if I’m wrong, it doesn’t mention being able to duplicate the emoncmsorg config section. It seems obvious now, and especially obvious to me having read the code now. But it wasn’t obvious when reading that page.
I hadn’t seen this. I hadn’t thought to search the old forums actually - that is something I’ll need to remember to do from now on, thanks!
Doesn’t emonhub need to be restarted after its conf file is modified?
i.e.
sudo service emonhub restart
or a reboot?
I didn’t need to. I believe it re-checks the config every so often and updates itself as necessary.
It’s emonhub.conf
that needs to be edited and EmonHubEmoncmsHTTPInterfacer
section duplicated with a different name e.g.
[[emoncmsorg]]
[[[init_settings]]]
[[[runtimesettings]]]
pubchannels = ToRFM12,
subchannels = ToEmonCMS,
url = https://emoncms.org
apikey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
senddata = 1 # Enable sending data to Emoncms.org
sendstatus = 1 # Enable sending WAN IP to Emoncms.org MyIP > https://emoncms.org/myip/list
sendinterval= 30 # Bulk send interval to Emoncms.org in seconds
[[emoncms2]]
[[[init_settings]]]
url = https://<IP/URL of emoncms sever>/emoncms
You probably also want to remove the myip
from the second server unless you have MyIP installed on your emoncms server.
Good luck
@glyn.hudson Doesn’t this need mentioning in the configuration.md file? It’s not the first time this question’s been asked.
Thanks! Merged
Hi there.
I am posting with my emonpi to a local emoncms server.
Now I will start posting to emoncms.org too (I mean in parallel)
I have an emonesp too (actually two… you may remember that Glyn ;-)) and wanted to post too on two server. local and remote.
Is it possible? not through the gui I guess…?
Is it possible at all?
Alternatively can I Sync somehow my local emoncms to emoncms.org?
TX
Plus : i habe been trying for the last hour to post mqtt from the emonesp to emonpi but I can’t connect. I am sure the emonpi mqtt server is up and running as I can see messages using a client
Solved. Sorry. Stupid typo.
