I have two post processes to combine the two phases of my energy monitoring into a single value to render in the My Electric Application. I noticed today that the post process had not been running for two days. And after cliking the “run” option it still ends up running a bunch of “points” behind and the feeds list indicate it’s over an hour behind.
Unless you’re electrical service is 3-phase, what you’ve got is split-phase service.
i.e. a single phase split into two legs that are 180° opposite each other with respect to the neutral leg.
