i know there are Emoncms Docker...run Emoncms on your machine in 4 commands!
that seems to still have something on the todo list thou, and it deals with the command line too that i’m not a fan of since there is not much ui control
i was wonderin if anybody has done it via portainer?
for esphome i did this to make a “stack”:
version: '3'
services:
  esphome:
    container_name: esphome
    image: ghcr.io/esphome/esphome
    volumes:
      - /path/to/esphome/config:/config
      - /etc/localtime:/etc/localtime:ro
    restart: unless-stopped
    privileged: true
    ports:
      - 6052:6052
    network_mode: host
currently i use a combo of GitHub - sprintcube/docker-compose-lamp: A basic LAMP stack environment built using Docker Compose. and adding emoncms to that, but that one is kind of messy too and no control from portainer either
@TrystanLea @glyn.hudson
is the stack file i provided the same as docker-compose.yml ?
or do i miss something?
so no that was not the case
Sorry Bo, Im struggling to follow what you are doing above
What is the stack file? Im probably not familiar enough with stacks to help…
stack file is prob the wrong term, but its the text you insert in portainer to deploy the stack
in the above picture you just enter a name, then in the text box insert the text
version: '3'
services:
  esphome:
    volumes:
    privileged: true
    ports:
      - 6052:6052
    network_mode: host
and hit deploy and after a while i have esphome running to compile firmware for my esphome devices
makes it dead simple for os NOOP’s to lunch something and there is no command line work
