Pi Zero W - emonSD-10Nov22 - Nothing on boot
There have been issues with the PiZero because of the architecture.
I’m pretty sure we found you needed to build emoncms from the scripts rather than the pre-built image. I thought something had been added to the docs to this effect, but cannot find it. @TrystanLea - I thought we had added a list of compatible Pis, but cannot see it so if it is there, it isn’t prominent enough :frowning:
I was also sure that I had done a build guide for the Pi Zero, but cannot find it. Best I can find is this thread from Feb.
However, RaspberryOS has changed since then so it might no longer work :frowning:
Follow this instruction to install base OS. EmonScripts: SD Card Preparation for RaspberryPi — OpenEnergyMonitor 0.0.1 documentation
Don’t include the WiFi module in the emonscript config.
