Hi
I am building a new system on a Pi3. Following Glyn’s suggestion I used the emonSD-03may16 image as a starting point.
I installed backup on my old system and after a few hiccups with file paths I successfully exported from 8.4 and imported into low-write 9.7.2. Everything was OK but I noticed I had no phpfiwa directory. Reading on I see the suggestion is to convert to phpfina.
I installed usefulscripts and tried phpfiwa_to_phpfina.php but got the following errors:-
[email protected] /var/www/emoncms/usefulscripts/convertdata $ sudo php phpfito_phpfina.php
PHPFIWA to PHPFINA conversion script
Is your setup a standard emonpi or emonbase? (y/n): y
PHP Notice: Undefined variable: redis_server in /var/www/emoncms/usefulscripts/convertdata/phpfiwa_to_phpfina.php on line 53
PHP Warning: Redis::connect(): php_network_getaddresses: getaddrinfo failed: Name or service not known in /var/www/emoncms/usefulscripts/convertdata/phpfiwa_to_phpfina.php on line 53
PHP Notice: Undefined variable: redis_server in /var/www/emoncms/usefulscripts/convertdata/phpfiwa_to_phpfina.php on line 54
Can't connect to redis at : , it may be that redis-server is not installed or started see readme for redis installation
What is the best way to proceed?
Regards
Ian
