I have some feeds that have stopped updating these are old devices probably not seen for a few months.
i see in this post a fix was done but no mention of what it was.
https://openenergymonitor.org/emon/node/12355
Below is a sample of the log file
running latest version of emoncms self hosted.
Thanks In Advance Dafydd
2016-10-01 10:40:49.297|WARN|PHPFina.php|post() padding max block size exeeded id=71, 1204667 dp
2016-10-01 10:40:49.308|WARN|PHPFina.php|post() padding max block size exeeded id=70, 1204667 dp
2016-10-01 10:40:55.169|WARN|PHPFina.php|post() padding max block size exeeded id=66, 1204668 dp
2016-10-01 10:40:55.187|WARN|PHPFina.php|post() padding max block size exeeded id=72, 1204668 dp
2016-10-01 10:40:55.191|WARN|PHPFina.php|post() padding max block size exeeded id=67, 1204668 dp
2016-10-01 10:40:55.198|WARN|PHPFina.php|post() padding max block size exeeded id=68, 1204668 dp
2016-10-01 10:40:55.205|WARN|PHPFina.php|post() padding max block size exeeded id=69, 1204668 dp
2016-10-01 10:40:55.213|WARN|PHPFina.php|post() padding max block size exeeded id=71, 1204668 dp
2016-10-01 10:40:55.219|WARN|PHPFina.php|post() padding max block size exeeded id=70, 1204668 dp
