Noticed these error messages in the log file a few days ago, and been meaning to follow up… But system is now almost broken - lost inputs, mqtt broker erratic etc.
System is an emonBase with a few emonTxs, emonThs and some bespoke RFM sensors.
I thought it might be due to lack of disk space on /dev/root as it was 95% full, so removed node-red and npm which freed up about 150 MB. Rebooted etc but still missing plenty of inputs. The SD card is a 3 month old quality card, so should be OK. I suspect the lack of disk space triggered a problem, which has now cascaded. I think it will need a fresh install, but interested in what caused this error message.
2020-05-04 22:27:30.289|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
2020-05-04 22:27:30.291|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
2020-05-04 22:27:30.292|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
2020-05-04 22:27:30.297|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
2020-05-04 22:27:30.298|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
2020-05-04 22:27:30.305|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
2020-05-04 22:27:30.306|WARN|PHPFina.php|PHPFina:get_meta start_time already defined but npoints is 0
repeated every few seconds, so thousands during a day.
Server Information
Server Information
Services
  • emonhub :- Active Running
  • emoncms_mqtt :- Active Running
  • feedwriter :- Active Running - sleep 300s 143 feed points pending write
  • service-runner :- Active Running
  • emonPiLCD :- Inactive Dead
  • redis-server :- Active Running
  • mosquitto :- Active Running
  • demandshaper :- Active Running
Emoncms
Server
  • OS :- Linux 4.19.97-v7+
  • Host :- emonpi2 | emonpi2 | (192.168.20.126)
  • Date :- 2020-05-05 18:38:36 AEST
  • Uptime :- 18:38:36 up 7:10, 2 users, load average: 0.50, 0.35, 0.19
Memory
  • RAM :- Used: 22.77%
    • Total :- 975.62 MB
    • Used :- 222.15 MB
    • Free :- 753.47 MB
  • Swap :- Used: 0.00%
    • Total :- 100 MB
    • Used :- 0 B
    • Free :- 100 MB
      Write Load Period
Disk
  • / :- Used: 91.30%
    • Total :- 3.92 GB
    • Used :- 3.58 GB
    • Free :- 151.74 MB
    • Write Load :- 565.4 B/s (6 hours 53 mins)
  • /var/opt/emoncms :- Used: 7.59%
    • Total :- 10 GB
    • Used :- 777.54 MB
    • Free :- 8.74 GB
    • Write Load :- 78.15 B/s (6 hours 53 mins)
  • /boot :- Used: 20.71%
    • Total :- 252.05 MB
    • Used :- 52.21 MB
    • Free :- 199.84 MB
    • Write Load :- 0 B/s (6 hours 53 mins)
  • /var/log :- Used: 59.70%
    • Total :- 50 MB
    • Used :- 29.85 MB
    • Free :- 20.15 MB
    • Write Load :- n/a
HTTP
  • Server :- Apache/2.4.38 (Raspbian) HTTP/1.1 CGI/1.1 80
MySQL
  • Version :- 5.5.5-10.3.17-MariaDB-0+deb10u1
  • Host :- localhost:6379 (127.0.0.1)
  • Date :- 2020-05-05 18:38:36 (UTC 10:00‌​)
  • Stats :- Uptime: 26029 Threads: 15 Questions: 123814 Slow queries: 0 Opens: 49 Flush tables: 1 Open tables: 43 Queries per second avg: 4.756
Redis
  • Version :-
    • Redis Server :- 5.0.3
    • PHP Redis :- 5.1.1
  • Size :- 233 keys (819.25K)
  • Uptime :- 0 days
MQTT Server
  • Version :- Mosquitto 1.5.7
  • Host :- localhost:1883 (127.0.0.1)
PHP
  • Version :- 7.3.11-1~deb10u1 (Zend Version 3.3.11)
  • Modules :- apache2handlercalendar Core ctype curl date dom v20031129exif fileinfo filter ftp gd gettext hash iconv json v1.7.0libxml mbstring mosquitto v0.4.0mysqli mysqlnd vmysqlnd 5.0.12-dev - 20150407 - $Id: 7cc7cc96e675f6d72e5cf0f267f48e167c2abb23 $openssl pcre PDO pdo_mysql Phar posix readline redis v5.1.1Reflection session shmop SimpleXML sockets sodium SPL standard sysvmsg sysvsem sysvshm tokenizer wddx xml xmlreader xmlwriter xsl Zend OPcache zlib
Pi
  • Model :- Raspberry Pi 3 Model B Rev 1.2 - 1GB (Sony UK)
  • Serial num. :- 5F51CEB5
  • Temperature :- 47.24°C - 47.2°C
  • emonpiRelease :- emonSD-02Oct19
  • File-system :- read-write
Client Information
Client Information
HTTP
  • Browser :- Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/81.0.4044.129 Safari/537.36
  • Language :- en-US,en;q=0.9,nb;q=0.8,zu;q=0.7
Window
  • Size :- 1347 x 743
Screen
  • Resolution :- 1280 x 800
Hello @icenov, could you check the contents and file permissions of your PHPFina data files, could you try the following and paste the result here?
ls -lh /var/opt/emoncms/phpfina
or if an older SD card
ls -lh /home/pi/data/phpfina
Hi @TrystanLea, here is the output of ls:
total 639M
-rw-r--r-- 1 www-data root     1.3M May  4 20:40 111.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:14 111.meta
-rw-r--r-- 1 www-data root     827K Apr 10 12:14 116.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:14 116.meta
-rw-r--r-- 1 www-data root        8 Apr 10 12:14 117.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 117.meta
-rw-r--r-- 1 www-data root      41M May  5 08:44 11.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:11 11.meta
-rw-r--r-- 1 www-data root      41M May  5 08:44 12.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 12.meta
-rw-r--r-- 1 www-data root     994K May  4 20:40 131.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 131.meta
-rw-r--r-- 1 www-data root     993K May  4 20:40 133.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:14 133.meta
-rw-r--r-- 1 www-data www-data 606K May  6 08:25 134.dat
-rw-r--r-- 1 www-data www-data   16 Apr 18 10:02 134.meta
-rw-r--r-- 1 www-data root      41M May  5 08:44 13.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:10 13.meta
-rw-r--r-- 1 www-data root      41M May  5 08:44 14.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 14.meta
-rw-r--r-- 1 www-data root      41M May  5 08:44 15.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:10 15.meta
-rw-r--r-- 1 www-data root      40M May  5 19:09 23.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:11 23.meta
-rw-r--r-- 1 www-data root     6.6M May  5 17:59 28.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 28.meta
-rw-r--r-- 1 www-data root     6.6M May  5 17:59 29.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 29.meta
-rw-r--r-- 1 www-data root     6.6M May  6 08:25 30.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 30.meta
-rw-r--r-- 1 www-data root     6.6M May  6 08:25 31.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 31.meta
-rw-r--r-- 1 www-data root      39M May  5 08:44 33.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 33.meta
-rw-r--r-- 1 www-data root      39M May  5 08:44 34.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:10 34.meta
-rw-r--r-- 1 www-data root      38M May  6 08:25 35.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:10 35.meta
-rw-r--r-- 1 www-data root      38M May  5 17:59 36.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:10 36.meta
-rw-r--r-- 1 www-data root      33M May  5 19:09 38.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 38.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:11 39.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 40.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 41.meta
-rw-r--r-- 1 www-data root      22M May  5 19:09 43.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 43.meta
-rw-r--r-- 1 www-data root     4.5M Apr 10 12:08 45.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 45.meta
-rw-r--r-- 1 www-data root      22M May  5 19:09 46.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 46.meta
-rw-r--r-- 1 www-data root      372 Apr 10 12:06 47.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:09 47.meta
-rw-r--r-- 1 www-data root      364 Apr 10 12:10 48.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 48.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:08 50.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:06 51.meta
-rw-r--r-- 1 www-data root     2.1M Apr 10 12:06 52.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:09 52.meta
-rw-r--r-- 1 www-data root        0 Apr 10 12:11 59.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:06 59.meta
-rw-r--r-- 1 www-data root      18M May  4 20:40 60.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:11 60.meta
-rw-r--r-- 1 www-data root      18M May  4 20:40 61.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:11 61.meta
-rw-r--r-- 1 www-data root      18M May  4 20:40 62.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:12 62.meta
-rw-r--r-- 1 www-data root      18M May  4 20:40 63.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:12 63.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:12 64.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:12 65.meta
-rw-r--r-- 1 www-data root       16 Apr 10 12:12 66.meta
-rw-r--r-- 1 www-data root      13M Apr 10 12:13 67.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:12 67.meta
-rw-r--r-- 1 www-data root      11M Apr 10 12:13 76.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 76.meta
-rw-r--r-- 1 www-data root      11M Apr 10 12:13 77.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 77.meta
-rw-r--r-- 1 www-data root     9.3M Apr 10 12:13 80.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 80.meta
-rw-r--r-- 1 www-data root     9.4M May  4 20:40 86.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 86.meta
-rw-r--r-- 1 www-data root     9.4M May  4 20:40 87.dat
-rw-r--r-- 1 www-data root       16 Apr 10 12:13 87.meta
My guess is that the errors are resulting from this feed.
Can you find feedid 59 in your emoncms interface? (hover over the feed name to see the feed id and other details). You could try and delete it from the feed list interface if not needed.
OK - it was an old feed (one of 3) which are now deleted. But strangely, the error messages stopped last night (according to log) before I saw your reply and deleted the feed. There’s been no new log entries since then (I’m using “warn” level - so maybe all good), but I might change that to info and recheck.
