Hi all,
I noted some time back that my system ( HeatpumpMonitor.org ) was flagged with an error relating to phantom heat reporting. Having solved that back in around early May, (feed was calculating heat solely on delta T regardless if compressor running or not), I thought that the error would drop off after some time.
Alas, it remains. Is there any way to check if there’s ongoing metering issues with my system (excluding where my local emoncms instance went down for a couple of months and I didn’t notice!). Keen to get back on the main dashboard if poss. Is it worth removing all the old data before say end of July so it’s a clean feed?
Grateful for suggestions!
