Optical and Temperature Sensor Data dropped for Exactly One Hour in EmonCMS
Hi
Has anyone one had the following problem with data from an optical pulse sensor and DS18B20 being dropped periodically from EmonCMS for exactly an hour? The data from the two sensors are transferred to the EmonPi via a terminal block breaout board. When data is dropped both are dropped together, always on the hour and for exactly an hour. No obvious external causes and its not the same hour and not every day or even every week. But still very annoying. Temperature data from Sontex not affected.
Any advice?
Peter
You mention Sontex – is this a Heat Pump Monitor rather than regular emonPi and emonCMS?
If it is, the price you paid includes on-line support from The Shop, so your best course of action is to contact [email protected]
